Maintenance of Harvester gas engine range extender
Macallan 18
Traveler Harvester
Jim
TN <> MI
2021 Jeep Gladiator Rubicon
We don't know which VW engine will be used as the Harvester gas range extender yet, but I assume it will be a simpler and smaller engine.
I'm curious what maintenance we'll need to do on the Harvester -- will it be the typical oil change interval for that engine or something different.
Also, with its special placement it'll be interesting to see where to fill and drain the engine oil.
TheVirtualTim
Traveler Harvester
Dearborn, MI
’21 Mach-E First Edition, ‘23 Mach-E GT Performance
A lot of cars now monitor engine usage and the car tells the driver when it is time to change the oil (rather than a pre-determined interval based on miles or months) based on usage patterns.
I have no special knowledge … but these systems are pretty common.
soedesh
Traveler Harvester
Shawn
'82 VW Rabbit 1.8T, '10 Volvo XC60 T6, '13 Chevy Volt, '19 Volvo XC60 T6 R-desig
Chevy volt is kind of technically similar, and that’s how it works.
RickS2R
Rick
Cadillac Lyriq, Tesla Y
Actually, it seems like it is closer to the BMW i3 REX...the Volt could mechanically couple the engine to the drivetrains, sounds like this is a pure generator, like BMW did...they used a BMW scooter motor.
Mousehunter
Traveler EV
South Texas
F250,, LJ, Golf TDI, Tacoma
I can only extrapolate from a lot of other gas engines. 100-200hr service intervals are the norm. When I look at engines with hour meters rather than odometers - it is the case. If I do quick math - it basically holds for odometer engines as well. Add to that, many engines have a minimum of 1 year service intervals - not sure if it because of age related oil break down or something else.
underkuver
VA
too many toys
Agree, this sounds much more akin to the i3 REX. We had one and loved it.
Couple interesting facts to note. CA CARB emissions forced BMW to limit the range the generator could go by software limiting the fuel tank size. Only US BMWs had this.
You could hack the car to allow more fuel in the tank and go further. Another amazing hack was the ability to force the generator on. That 600cc scooter engine made noise and it was much better hearing it at highway speeds than in your neighborhood/garage.
Hopefully Scout allows for push-button Harvesting!
P.S. BMW REX maintenance intervals were 5K miles or 12-months.
Foobar
Terra Harvester
New York
'23 Rivian R1T, '19 Tesla Model 3P, '22 Energica Eva Ribelle
I would plan to change oil on any ICE engine on at least an annual basis, even if the engine isn't getting much use. Oil breaks down over time and the generally accepted practice is to do it no less than once a year.
soedesh
Traveler Harvester
Shawn
My understanding is that my Gen 1 Volt mostly uses the engine to drive the generator and only direct couples the engine to the drivetrain above 50mph, presumably for efficiency. If you need to pass it decouples and uses pure electric.
My original point was that the engine/generator is capable of fully operating the vehicle and not just some kind of "booster". You can run the car indefinitely on gas and have full power. Also, the car keeps track of the engine hours and alerts the driver when an oil change is required, not based on miles.
RickS2R
Rick
Yep, I bought that software that let me set the REX engagement point at any battery %, made the car infinitely more useful.
mfreidberg
A few
It would be great to see a cutting edge ultra compact power plant like a Wankel or perhaps one like Liquid Piston is developing for drones: https://www.liquidpiston.com/
Mazda used a Wankel engine for their range-extended MX-30:
https://insideevs.com/reviews/712120/mazda-mx-30-range-extender/
I do wonder about the rotary engine used for this purpose - they're famously smooth, but also notoriously thirsty. If the whole point is efficiency, is a rotary engine going to use more or less gas than a traditional cylinder engine for the same energy output?
soedesh
Traveler Harvester
Shawn
Oh, you were replying to the oil change stuff. Gotcha. I thought you were replying to the operation of the Voltec drive.
ClayCollins
Clay
Houston, TX
2022 GMC Yukon, 2012 Jaguar XF, 1963 MGB
I do know the Wankel engines suffer from apex seal wear which limits their life. Mazda has improved, but not eliminated this problem. Perhaps the reduced weight and size would offset the efficiency. I don’t know if Liquid Piston’s design is better in efficiency. I do know they claim to have solved the apex wear problem.
timmyhil
Traveler Harvester
Timmy
NOYB, NJ
mini countryman 2019 s all4, scout800
My guess is that its maintenance will be around 4,000-8,000hrs of run. Only because it will most likely run at the most torque made rpm which would in theory create less heat and wear to oil and internals. The reason it would be the torquiest rpm is because it would be connected to some kind of alternator or to a special alternator crankshaft to charge the battery.
