Running boards standard for which trims? Aftermarket options?
Seabass
Limited
Sebastian
Connecticut
Jeep
When I ordered my limited I did not select running boards. I read that it might be standard, why the option to add? Does it come with boards installed? Are there any places where aftermarket are cheaper to buy, or should I have them installed at the dealer for 1250 as the option? I could not yet find a place that offer 2025 4runner boards. I do not want the running boards. Thanks
Administrator
Administrator
Staff member
Jay
Highlander
Fixed running boards are standard on the Limited, TRD Off-Road, TRD Off-Road Premium and Platinum trims. And optional on the SR5.
This optional vs. standard equipment chart is from:
Trims Comparison Chart: Optional vs. Standard features, equipment, options for 2025 4Runner
2025 Toyota 4runner Running boards standard for which trims? Aftermarket options? runningboards optional standard 2025 4runner 6th gen
Seabass
Limited
Sebastian
Connecticut
Jeep
So if I did not mention Running boards to the dealer when I ordered it, it will come with it? I specified color, seat color, 4 wheel drive, and dash camera. So you are saying that boards will come installed?
Jack
Jack
SLC, UT
FJ
That document the @Administrator cited was released a few weeks old and sometimes these docs have errors that are later corrected, but if you check the current live 2025 4Runner build & price at Toyota.com, you'll see that it still shows Fixed Running Boards come standard with the Limited trim (I posted screenshot below).
So yes you shouldn't have to mention it to the dealer since it'll come standard on your 4Runner Limited.
2025 Toyota 4runner Running boards standard for which trims? Aftermarket options? fixed running boards 2025 4runner
LLL1990
United States
Toyota Camry and Ford F-150
The optional running boards on the Limited are power deploying running boards. The fixed running boards are standard.
TrappedinNYC
Queens, NY
2011 RAV4 and 2001 4Runner
did your dealer estimate when your limited will be delivered and how much are they quoting you for it?
