Harvester
ejf
Traveler Harvester
eric
columbia south carolina
toyota
wondering with the harvester, can you use it s a generator for your house if you lose power or for a camper, campsite etc
the electrical plugs near the charging port make it awesome for tailgating.
vrgruver
Traveler EV
BMW wagon, M3, 911c2s
Most likely only a few things. A whole house generator is $7-15,000. It comes down to the kilowatts you need. Plus, it would be a drag that you are away from home when the power is out and your fridges and family have no juice.
colinnwn
Terra Harvester
Colin
Dallas
Ford F150
For a camper or campsite yes, they've already said there is a Harvester camping mode.
For a whole house generator - probably. They said it would support bi-directional charging in one of the press discussions I saw. That doesn't indicate if it will support grid independent (electrical outage with a transfer switch) or grid following (must have grid electricity coming in) or both.
swambeach
Traveler Harvester
Shawn
1971 Ford Bronco, 1999 Ford F250, 2023 Ford Mach E
Yes, the charging port will be bi-directional per Scout; however, it would all depend on how your house is wired.
gregdouble
Traveler Harvester
Greg
Mercer Island, Wa
Website
www.GustosAuto.com
Ford F150, Mercedes Gle, Yamaha MT07
i power my whole house with a 7500w predator that was like $1200
my house is only like 2500 sq ft tho it’s not huge
vrgruver
Traveler EV
At the recommended 3500w per ton for A/C, and a 2500 square foot house receiving a 3-5 ton A/C unit(depends on vaulted ceilings and such), you would need a 10,500-17,500w generator. That is what I based my recommendation for a 22-25kw generator. Good to hear about your real world usage example.
gregdouble
Traveler Harvester
Greg
Mercer Island, Wa
Website
www.GustosAuto.com
It’s cold here when we need the generator for the house, so I never ran the AC off the generator. Seattle area we just need it when storms take out trees and transformers start blowing
OrionOffroad
Traveler Harvester
Orion
Arizona
Toyota 4Runner
I want to some clarity on how this works from a convenience perspective...
I fill the harvester with Gas and then run it, and wait in a parking lot while it charges the ostensibly smaller battery at a very slow rate?
Or can I just start driving again once it has gas, and feasibly it's just in a kind of perpetually "charging" state on the battery similar to using a laptop while plugged in?
Half my attraction to this vehicle is the appeal of electric function (quiet drive train, torque for off-road power and what is likely to be heavy vehicle) but charge times and charging networks are the biggest gripes I have with electric. Hoping this gets cleared up.
PMurphy
Traveler EV
Patrick
Wisconsin
Jeep Gladiator diesel, Ram TRX/1500 diesel
Typically the Harvester will kick in as you are driving once the battery gets down to 60% (my estimate). The idea is to keep the battery from loosing to much reserve power for high demand needs (towing, passing etc). May cycle on and off or keep running based on power demand as you are driving. Intended to keep you moving with seamless integration of battery/generator power.
OrionOffroad
Traveler Harvester
Orion
Arizona
Toyota 4Runner
In the event I'm down to say, 50 miles of range then; and I have a gas station nearby, can I just expect that the vehicle runs the generator the whole drive to my destination until I charge it to full again? I wonder if it's possible to charge to full on the generator alone (assuming you kept adding gas)
PMurphy
Traveler EV
Patrick
Wisconsin
The generator “may” have enough capacity to keep you moving at a very low battery charge level depending on demand. I know the battery size is smaller and has different chemistry that will allow it to be drawn down more safely to low levels. Intent is to keep you moving the longest time possible based on combo of existing battery charge and fuel for Harvester (500 mile estimate has been cited in earlier discussions). Software will integrate power sources to reach maximum distance that is safe for the system to operate.
colinnwn
Terra Harvester
Colin
Dallas
Ford F150
Scott the CEO has said the Harvester will be no compromises gas and go when the battery is empty.
That's probably a little bit of hyperbole for example if you are heavy towing. But definitely it should be gas and go for highway speeds at reasonable loads.
E90400K
Traveler EV
Francis
Toledo
E90 & Mach E
Yeah. I get by with just a classic 4,500W Generac with their i-series engine. It'll run 24/7 for days on end. In the summer I just can't run the AC with it. And for the hot water heater I need to drop all other loads. I'm on a well (so it's critical power). DIY (safely) back fed into my breaker panel w/ a DIY custom extension cord.
I bought it used for $250 (but never run) from a work colleague who bought it for the turn-of-the-century power outages that never came. LOL
E90400K
Traveler EV
Francis
Toledo
E90 & Mach E
It is a series hybrid, which means the engine-generator keeps the battery at a minimum state of charge that meets the load demand placed on the drivetrain. Unless you run the fuel tank to empty and force the EV side of the drivetrain to power the vehicle, you will never be in a situation with just 50 miles left of battery range. You keep the Harvester fueled up just like your ICEV, the system takes care of the battery state of charge.
