I recently installed a sub in my 2022 4Runner and decided to add another one to my Trailhunter. For the setup, I used the 10" Rockford Amp/Sub combo, which sounded great in my previous 4Runner. To make the install easier, I went with the Tacotunes kit, since I have the JBL speakers. I also ordered the speaker wiring harness and remote turn-on kit (skipped the LCI Pro, since the sub can handle high-level inputs).
One of the advantages of the Hybrid setup is that the battery is in the back, which made running the power wires super simple.
I also had to disable the artificial engine noise, as another post here mentioned. Without doing that, the sub produced a low rumbling effect. I picked up the Carista app and was able to disable that feature with ease.
I'm really happy with both the install and the sound quality.
https://tacotunes.com/shop/2025-toy...-package-modified-signal-post-jbl-amp-signal/
https://www.amazon.com/dp/B007AQ2W2Q?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
https://www.amazon.com/dp/B0BBS73F6J?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2
