Digital Key Issues
JONNYBOSCO
Limited
JOHN
SPRING HILL, FL
2025 4 RUNNER LIMITED HYBRID 4WD
It’s been very annoying that the Toyota App, Digital Key, Remote Start, Locking / Unlocking doors does not work on my new 2025. It worked perfect on my 2022. I’ll TRY again to REMOVE the Vehicle From the APP, remove and re-install it again. Anyone else having issues using the digital key on their vehicle?
TrdProGirl84
Georgia
2025 Toyota 4Runner TRD Pro
My Pro didn’t come with the digital key. I believe that was a $245 add on but mine was already built before I could say yes. So mine doesn’t have it. I don’t know that it’s even worth it truly bc I always use the Toyota App anyway.
JONNYBOSCO
Limited
JOHN
SPRING HILL, FL
I use the app too and pay for it.. I paid for the digital key too.. but it’s pissing me off that I can’t make it work like it should.
Michigan
2020 Navigator, 2014 MDX, 1993 Taurus SHO
I have used it without issue (aside from the app logging me out once while I was out for some reason. Logged back in and worked fine, didn't need to set up digital key again.)
I take it you did the bluetooth key download that the app prompts you to?
scorp
CA
None
It seems pretty glitchy on mine, sometimes it recognizes the digital key and unlocks the door, other times I have to try multiple times for it to work. (this is with me holding the phone in my hand) I'll try to up the key to high sensitivity to see if that works, but if not, I'm probably just going to plan to carry the fob with me.
