TwoJacks
Traveler EV
VT
Defender
That’s the big question. If the Harvester is big enough to maintain charge under normal driving, and they don’t let the battery go below 20%, then my guess is yes, you could fill up and go. Question is whether that will hold true while towing. They might try and keep the battery at 50% under towing mode in order to avoid depleting the battery while you still have gas. The complexity and permutations a a bit mind boggling, and the similar range after depleting the battery is making me ok with choosing the BEV or just sticking with a Rivian max pack. The harvester seems less appealing the more I think sbout it.
dls235
Terra Harvester
Levi
2023 Ford Maverick
Trying to understand this gas extender, and I know there isn’t a ton of information out there. Theoretically, say I’m on a long trip across states, I could just keep refilling the gas extender to keep the battery charged, right? I know this wouldn’t give me full electric charge range, but my guess is it would give me the extended range of ~150 miles or so to keep going?
Mr._Bill
Terra Harvester
Bill
2023 Jeep Gladiator, 2013 Nissan Leaf
That's the general idea. Until we have the details on the generator package, how fast it will charge, and how much charge you can get from a tank of fuel, it's all speculation.
TwoJacks
Traveler EV
VT
Defender
more like you could keep going another 350 miles. Everything the company has put out so far indicates a 150 mile battery and an extra 350 miles of range in gas. So unless you stop to plug in somewhere, filling up with gas should get you another 350 for each tank but no more—and probably half that towing.
rfk
Traveler EV
VA
2004 Volvo XC90, 250k miles and counting.
Imagine the extender fires up at maybe 50% of pure EV range (75 miles? 150 miles?). That then slows the rate of discharge of the remaining battery to push range to 500 miles or whatever. But not enough generation coming from extender to power the vehicle solo. Once you exhaust battery, you'll need to stop to recharge w/ plug-in or let the generator run while you visit a campsite or pub.
rfk
Traveler EV
VA
Do you think there will be a solar option over the glass panel panoramic roof or plug in a portable solar panel that can charge some while out in the front country?
I'd gladly overpay for a solar panel w/in fixed glass or steel roof, just because. But given electrochromic was reportedly nixed due to cost vs. projected take rate, I suspect SM offering solar panel is a non-starter. Plus my understanding is that a small roof panel won't actually charge the battery all that much - maybe a few miles/hour?
Timmdodge60
Terra EV
Orlando
Lexus RX350
rodhx
Rod
Alabama
2022 Rivian R1T, BWM m235
From a miles/hour view 110V charging will likely only add 1-2 mi/hr, similar to my Rivian, so a small solar panel will be more of a novelty from a vehicle charging standpoint.
Bender
Traveler Harvester
Boise
2021 Ford Bronco
I'm thinking they could decide when to fire up the RE based on predicted usage (e.g. you put in a map destination that goes over Sonora Pass) or backwards-looking usage (e.g. the temp is 20F and you're towing a trailer). Lots of existing or predicted load? Fire up the RE ASAP. Driving around town on a warm spring day? Don't turn on the RE until the battery is at 40%
dls235
Terra Harvester
Levi
2023 Ford Maverick
I like that. Would be pretty neat for it to work that way.
Mr._Bill
Terra Harvester
Bill
Wishful thinking. The vehicle doesn't have the computing power, and a bunch of people will be complaining about their privacy being invaded.
It will be a simpler algorithm, based on charge level and demand, and possibly on the amount of fuel in the tank.
Bender
Traveler Harvester
Boise
2021 Ford Bronco
Even that would be good. Temperature and weight would both affect the demand measurement, so they could turn on the RE earlier
Mr._Bill
Terra Harvester
Bill
A lot will depend on the size of the battery pack and the generator package. If done as currently being speculated, there will be a lot of complaints about the generator coming on too soon and running too often, and complaints from those getting stranded because they are preventing the generator from running.
rfk
Traveler EV
VA
...so does '150 miles' BEV range mean that's when RE will switch itself on by default? Reducing rate of discharge of the smaller battery and extending to '500 miles'?
Or does that mean that's when the smaller battery for EREV is exhausted w/ RE disabled, and you then need to park to plug-in and/or recharge via generator? So perhaps RE defaults to switch on around 75 or 100 miles?
