ToyoTech808
ToyoTech808
Honolulu
25 4runner
Could you use the tires on the TRD Off Road (265/70R18) with the TRD Pro wheels?
Yes. The 4runner TRD off road wheels is the same size as the Pro wheels, just the offset is different.
DangItsDen
Hayden
Austin, TX
2025 4Runner Off-Road Premium + 2015 4Runner Trail Edition
Just posting here the TRD Pro wheels part numbers and what you need to install. You would need valve stem kits and center caps since wheels do not come with them.
The Tacoma valve stems are different part numbers but are same when visually looking at them. They work and are way cheaper than the 4runner part numbers.
Center caps from various wheels can fit depending on the look that you want. Most are also cheaper than the TRD Pro ones.
PT998-89210-F2 IS TRD Pro Caps
PT998-35240-F2 is caps from TRD off road
90942-A5010 is valve stem kits. NO SENSORS.
With Non TRD Pro caps.
Any chance you have some pics up close of those center caps on those wheels? I want to swap out the red circle pro ones but not sure which to choose. Thanks!
ToyoTech808
ToyoTech808
Honolulu
25 4runner
2025 Toyota 4runner Part numbers for TRD PRO wheels, valve stem kit, center caps. Various center caps fit depending on the look you want. 1000020111
2025 Toyota 4runner Part numbers for TRD PRO wheels, valve stem kit, center caps. Various center caps fit depending on the look you want. 1000020112
