Pcm / preconditions
Doggo
Doggo
NYC
NA
This has happened many times and I'm not sure if I'm losing my mind or if it's a bug. In the US we get EA charging for 1y. From the PCM I select the fuel icon, select an EA charger, and then navigate there.
Tonight I had a 1.5h/70mile destination. Ambient is 52f. Battery is 52f. It never budged. No preheating etc. 10min out from the destination I cancel and redo it, no change. Get to the destination and it wouldn't hit more than 90kw when the battery was at 20%. EA had 10 350kw chargers there, others charging at 130kw there.
What am I doing wrong?
Nothing wrong most likely.
Not all EA chargers deliver at peak speed - how many stations have you had this issue with?
Doggo
Doggo
NYC
NA
2 Separate stations that I frequent. What strikes me as odd though is the battery didn't raise it's temp at all over 1.5h/70miles? It stuck to ambient.
I noticed there are two ways to pick a destination - when you click on a charging station icon you can set it as a destination or select it as a charging stop. When selecting a charger as a destination it will not preheat the battery, you have to use an option "add charging stop".
You can check it out - set a destination near your charger, use "show nearby chargers", click on a charger and there would be another way to add it to your trip by selecting "add charging stop". After adding the charger this way you will see a different icon with power and not a flag next to it.
I suppose the thinking behind this really bad UX is the charging planner works only when chargers are set as stops on the way to your final destination.
Generally adding a DC EVSE as a stopover in NAV will force the pre-conditioning - rather than as an ultimate destination. This will invoke the Charging Planner which manages the pre-conditioning.
Additionally, make sure the Charging Planner is active when planning any route as EVSEs are auto selected along with pre-conditioning of battery as part of your journey plan.
Something is not right the way the charging destination is selected since if it is selected correctly the battery will preheat and you observe in the left tube battery screen the increase in battery temperature and max charging rate possible. Macan EV marketing pages state that ideal battery temperature for charging is between 86F and 95F.
DISCLOSURE: I do not have Macan EV but this is how it works on Taycan and I am using Macan EV simulator screens to demonstrate the process.
You must use Navigation -> Charging Station screen as shown below to locate and select the charging station as destination.
Electric Macan EV Pcm / preconditions 1733838667512-j4
Then select the charging station.
Electric Macan EV Pcm / preconditions 1733838698297-lk
Then the proof of navigation to a charging station is on the right screen as shown here with its kW rating.
Electric Macan EV Pcm / preconditions 1733838891274-cr
Ontario, Canada
Macan ec turbo
I find the EA network inconsistent. One stop I will get 70kw the next 170kw.
Doggo
Doggo
NYC
NA
Thanks for taking the time to respond. I do exactly this and no dice.
Doggo
Doggo
NYC
NA
This looks to be the answer. Horrible UX decision. So backwards. Will test shortly again.
Thank you for replying.
