Rear Door Window Seal - Looks like its incorrectly fitted both sides
brumey
Tennessee USA
F350
Has anyone noticed or can you take a look at the top of the black rubber windows seal. It's on the rear doors, both matching and in the same place. It's the top horizontal seal, closest to the front doors. It does not overlap and dips down for about 4 inches. See attached picture.
2025 Toyota 4runner Rear Door Window Seal - Looks like its incorrectly fitted both sides Window Seal
Hacksaw
az
2025 4runner TRD-ORP
Yours is slightly more exaggerated than on mine but yes, similar on mine. If you take your thumbnail and slide it down from the painted metal above, down to the weatherstrip interface, the weatherstrip is slightly higher than the painted metal to the right of that 4" section, and the weatherstrip is either flush with or slightly lower than the painted metal within this 4" segment.
brumey
Tennessee USA
F350
So we can assume normal? Looks like crap now that I have noticed it :) I need to stop washing the car as I keep noticing new stuff....
72and10bulls
Derick
New Mexico
2024 Toyota 4Runner TRD Offroad Premium (Underground) 2019 Toyota Tacoma TRD
For real just looked at ours in the garage seems a little off but will double check it in the sun light.
Hacksaw
az
There must be a reason for it. I didn't roll the window down and check whether there's a "bump" in the underlying metal that the weatherstrip fits into (e.g. a spot weld or overlapping metal joint), compared to the parts to the right. Or maybe the top edge of the window glass itself is not perfectly horizontal and is slightly higher on the left and compresses the weatherstrip more on the left end when rolled all the way up.
Did you happen to roll the window down and jiggle or pull out and re-insert the weatherstrip to see if you can make it all uniform, if not for the window compressing it?
brumey
Tennessee USA
F350
I did roll the windows down and made a small effort to roll out some of the edge but I was not successful. I may try again this weekend.
Kennyg
TRD Sport
Ken
Albuquerque, NM
2025 4-Runner TRD Sport, 2009 Matrix Sport
Hmm. I wonder if this might be the reason for the wind noise some people, including me, are reporting?
jankphil
Limited
4Runner
Mine also does this, I don't really have any issues with wind noise though.
