Mousehunter
Traveler EV
South Texas
F250,, LJ, Golf TDI, Tacoma
A lot has been said about the interview-including that all the numbers are still subject to change. Personally I think the 5k limit was due to the Harvester being designed for max range when not towing. But that is a compromise that probably can easily be adjusted (but then the real question is should it be adjusted). Most people don't tow much if at all. Any significant reduction of total range could easily be more harmful to most people than a increase in maximum load while towing. Not to mention, significant is a very subjective term. Is 50miles significant, 100 miles?
Chavannigans
Traveler Harvester
2004 GX470, 2020 Honda Odyssey, 2024 Husqvarna Norden 901
Reduced payload from extra Harvester weight = Reduced towing capacity
The rear axle is only rated for so much weight
Not range related.
