Jpr18
Southern California
Everest 2025 4Runner ORP Hybrid
I recently switched my dashcam hardwire kit from the Mangoal kit to Dongar after finding out the Mangoal was a cheap knockoff and not thoroughly tested. Because these kits interface with expensive and sensitive electronics, I wanted something legit. And thankfully, Dongar was able to send me their brand new USB-C 10-pin Type B kit for testing. This is the kit you need if you have a Premium trim or higher.
Install was super easy, and I was able to tuck the Dongar module in the shroud so it's not exposed. The Mangoal wiring was too long and it was very difficult to stuff everything behind the shroud.
In terms of the camera itself, I like how it's easily removable from the dock and is pretty low profile in general. Video quality is fine. It's a pain to access the app when used in the car, as the car's Wi-Fi interferes. I either need to use a different phone that's not connected to Android Auto or bring the dashcam inside and hook it up to a power bank. The one other issue is that for some reason the time and date keeps getting out of sync.
2025 Toyota 4runner Viofo A119 Mini 2 Dash Cam + Dongar 10-pin Type B install in ORP 1000010000
2025 Toyota 4runner Viofo A119 Mini 2 Dash Cam + Dongar 10-pin Type B install in ORP 1000010028
2025 Toyota 4runner Viofo A119 Mini 2 Dash Cam + Dongar 10-pin Type B install in ORP 1000009990
tommyd52
Maine
4Runner
Does the power remain on when vehicle is off to capture any incidents when vehicle is parked?
Dongar
Site Sponsor
Kevin
Norcal
2024 Tacoma TRD OR
@Jpr18 thanks for the shoutout! I'll add here that we use OEM connectors whenever possible and we spec our wires per UL 1332 standards, among other things. Our USB modules are also designed in-house and are the only ones in this entire category that can output true USB-C including 12V which means you can even power a BlackVue, fast charge your iPhone, power radar, etc. The Mangoal, FitDVR stuff etc all use cloned connectors, unknow wiring, and their USB modules are 5V output only! It helps that we're a US-based company and have to do everything we can to mitigate the risks associated with things meant to protect our customers when we can whereas our clones don't need to worry about liability lol!
@tommyd52 we have a product that will keep your dashcam on while parked! See link in my sig below!
kekecarioca
_CAC_
2025 Trailhunter 4R -- 1999 4runner SR5 4x4 Manual
I have a Trailhunter : It has dimming mirror and digital mirror (same as tow package). What kit should I get? 10 or 5 pin?
Dongar
Site Sponsor
Kevin
Norcal
2024 Tacoma TRD OR
@kekecarioca The 10-pin Type B is a little quicker/easier to install and most would prefer it.
I'd still recommend the the 5-pin connector in the domelight because Toyota put that port there in the 6G for (their own dealer option) dashcams, so why keep it unused :cool:.
Archer
Mike
Orwigsburg, Pa.
2025 4 Runner TRD Pro
What am I missing here and what is the advantage of hooking up with this wiring vs. the wiring that comes with the A119. Does it add some type of feature or integrate to the screen?
I use the A119 in my company work vans and wanted to use one in the Pro. I was going to just hook it up with using their wiring like I did before, why shouldn't I? I'm fairly illiterate when it comes to tech.
Is the Mangoal what comes with the Viofo camera's
Dongar
Site Sponsor
Kevin
Norcal
2024 Tacoma TRD OR
@Archer the wiring included with the camera works just fine--it's routing it from the center console, around the footwell, up the pillar an to the center mirror which is suboptimal for many. So we have a product that plugs into wiring already going through your ceiling... that means quicker and neater installations.
We also have a second product that allows always-on power to your dashcam (i.e. 24/7 recording) without having to figure out how to tap it through the fuse box which is covered by two plastic panels and would require cutting plastics.
kekecarioca
_CAC_
Thanks for the info! I'm eying one right now!
