AC switches OFF and Car does not auto-lock anymore
macanchan
Allan
My AC keeps switching off automatically. Also the car stopped locking by itself when walking away...
Scheduled service but next available appointment with a loaner vehicle is 3 weeks from now...
ferrocinque
Francesco
Roma, Italy
The AC shutting off happened to me when I had an issue with the system caused by a defective pipe, which resulted in a complete loss of refrigerant gas.
Does the air conditioning work when it is set to ON?
I have no idea regarding the key issue.
macanchan
macanchan
Allan
No, the AC does not work when the AC is switched ON. When I switch it ON, it switches automatically to OFF.
The key issue I figured out.. I guess I dropped the spare key under the seat and it wouldnt lock itself in. :clap:
ron_b
Ron
California Central Coast, USA
@macanchan as far as the car, not auto locking when you walk away. That is a setting in the PCM you might want to verify it didn’t get turned off during a software update.
macanchan
macanchan
Allan
I did check the settings, it was enabled. The reason why it didnt lock was because I had unknowingly left a 2nd set of keys in the car.
ron_b
Ron
I understand completely. Now that I received my car and setup phone as a key and left it in the car while still carrying my physical key it fails to lock. Then I realized my issue, after first blaming the car. Will it ever forgive me???
macanchan
macanchan
Allan
Just dropped the car off and had quite a few updates required.
-Rework rear axle module cablet set
-Update software VR28.13
-Replace luggage compartment cover
-Replace plastic slide on seat belt
macanchan
macanchan
Allan
Software update VR28.13 seemed to fix my AC connection issue. Got the car back in record time!
