2026 macan ev turbo ride heights
tonyadduci
tony
chicago, il
porsche macan ev turbo
I just took delivery of a new 2026 Macan EV Turbo ordered in November of 2025. I had a 2024 Macan EV Turbo and loved it. Be advised that there is a difference in ride height between lifted/off-road 1 and off-road 2. This may help some of you who are just using the lifted state. However, you will need to select this off-road setting manually to get the maximum lift.
Note that the EV has 6 selectable ride height levels total, but focusing on the ones you asked about:
ModeGround ClearanceDelta from Normal
Normal185 mm (7.3")—
Lift (High Level I)205 mm (8.1")+20 mm
Off-Road I~205 mmActivates with Off-Road drive mode (+20 mm)
Off-Road II (High Level II)225 mm (8.9")+40 mm
Key notes from the Porsche Newsroom:
  • The standard ground clearance is 185 mm, and depending on speed, the body can be lowered by as much as 30 mm below that, which benefits range through reduced aerodynamic drag. At High Level II, ground clearance is raised to up to 225 mm.
  • In off-road driving mode, the Macan switches to all-wheel drive with a "rough road" configuration, and High Level I is activated, increasing ride height by 20 mm. A lift of 40 mm is achieved in High Level II.
You can configure which of the lift heights it uses for each mode in ... one of those panels :)
Anyway, I made off-road go to lift level II. Might as well!
tonyadduci
tony
chicago, il
where is that setting? I didn't find that. I know you can pick offroad which is lift level ii but...
