Annoying sound when on reverse
fsabek
Fuwad
Chicago suburbs
2021 Tesla model s, macan ev turbo waiting for software update at dealership
Is it only my car or do all Macan ev make that annoying rumble sound when on reverse?
fsabek
Fuwad
Chicago suburbs
I will try. However it seems to be also the same sound it makes when driving. Also when sitting down inside car while it is on and there no music on you can hear some sound maybe fan from hvac
Macan Turbo Electric ordered!
Confused, you’re saying that when you’re in your car, parked, you can hear the fan from the HVAC
 if the HVAC is running, isn’t that normal? Or is the HVAC off?
fsabek
Fuwad
Chicago suburbs
There is rumble like sound which I don’t think is how it should be and it is very low.
I have bad ocd and low sensitivity to stuff like unfortunately
Is it the same sound when you’re going reverse and when you’re idle, just with the HVAC on?
fsabek
Fuwad
Chicago suburbs
No the reverse is similar to the drive sound the inside is a different sound. Unless the inside is a much lesser form of the moving sound
ketje78
Gert
Dubai, UAE
Cayenne GTS ‘23 - 911 992.1 Carrera S ‘20
Might it be the AVAS - basically a sound to make others around the car aware it’s there?
fsabek
Fuwad
Chicago suburbs
I agree it most likely is. Cause it turns on when on reverse then goes away in drive. When you speed on drive I think it comes back
