- First Name
- Jon
- Jun 28, 2025
- US, CA
- 2025 Porsche Macan Turbo Electric PTS Viper Green
But how do you make them match the color?the little sensors should be easily removed and replaced
Everything is statistics. It might be that, normally, almost all cases are "within the curve" and work, but with some modification that "pushes the bell curve," some cases now fall outside the working parameters.if PPF is causing the issue it should be present all the time
That being said, punching/cutting holes around the radar sensor, rather than removing the entire film, would perhaps be a lower impact approach.
