Blind Spot Monitor Lights Abnormal
the little sensors should be easily removed and replaced
But how do you make them match the color?
if PPF is causing the issue it should be present all the time
Everything is statistics. It might be that, normally, almost all cases are "within the curve" and work, but with some modification that "pushes the bell curve," some cases now fall outside the working parameters.
That being said, punching/cutting holes around the radar sensor, rather than removing the entire film, would perhaps be a lower impact approach.
I dunno. is it practical to drive around without a rear facia. Can they throw a spare facia on it?
Seems to be plenty of members here that use PFF without issue.
I wouldn't think many service techs understand RADAR.
Thickness of paint has really no affect on RADAR performance at these frequencies. Paint that contains metal may. Interference from airport RADARs or military jammers may. Weak, improperly installed, or out of calibration RADARS is more likely. Problems with the camera on the underside of outside mirror is more likely. Did they get PFF on any of the cameras or acoustic sensors?
I just don't know how Porsche integrates the cameras with the blind spot RADARs. I know when the mirror cameras are not calibrated after a system reset, blind spot may not work. The front side collision warnings are all base on camera sensor video. The front collision warning is based on both the front RADAR and video.
Bob Taylor
Jupiter FL
2020 Range Rover
For what it worth... Google's Gemini App says:
On the Porsche Macan EV, the radar sensors for Lane Change Assist (blind spot protection) are located behind the rear bumper cover, one on each side (left and right).
Sensor Placement and Function
  • Location: They are mounted internally on the vehicle's rear quarter panels, hidden by the plastic bumper skin. This allows them to "see" through the bumper to monitor the areas diagonally behind and to the sides of the car.
  • Detection Range: These sensors typically monitor a range from approximately 6 mph to 155 mph. They detect vehicles in your blind spot or those approaching quickly from behind in adjacent lanes.
  • Interaction with Other Systems: These same rear radar sensors are also responsible for Rear Cross Traffic Alert, which warns you of approaching vehicles while you are reversing out of a parking spot.
Visual Warnings
When these sensors detect a vehicle in your blind spot, they trigger the LED warning lights located in the exterior side mirrors.
  • Information Level: If your turn signal is off, the LED stays dimly lit to inform you a vehicle is there.
  • Warning Level: If you activate your turn signal while a vehicle is detected, the LED flashes brightly to warn you against changing lanes.
Maintenance Tip
Because these sensors are located behind the rear bumper, it is important to keep the rear of the car relatively clean. Significant build-up of mud, heavy snow, or thick ice on the bumper surface can occasionally obstruct the radar’s ability to "see" through the plastic, which might trigger a "sensor blocked" message on your dashboard.
FirstEV
Sweden
This specific problem was an issue my head of service noticed himself when he test drove my car after one of the (many) issues it was in for. They took diagnostics and sent it to Porsche AG, about a week later it was an ECU/nano chip thing (can’t remember what it was called) that needed to be changed. Took a day to replace, worked flawless again after that.
Just save yourself some time and take it in for diagnostics, may save you a few days of speculating.
Bob Taylor
Jupiter FL
2020 Range Rover
That sounds more logical than repainting the bumper. My dealer just updated the software and said that should fix it (Nope) - Though there were fewer false positives than before the update.
EVowner
Macan 4s
Service center gave me their word that if problem will persist even after PPF removal from bumper they will pay for reinstallation. I will post update once I hear back from them.
My car has many other problems and after 6 months I can clearly see they have no idea how to fix it nor even properly diagnose it. From what I heard Porsche keeps insame amount of data (depending who you ask it is 60% or even more) from diagnostics to themeselves, so what issues are disclossed even to service centers or owners is fully under their control. On top of that Porsche seems to treat their cars as holy objects and service centers cant replace anything under warranty without their prior approval.
I can imagine this service model can maybe work for high end limited run models to protect their IP, but forcing it on mass produced models is insame.
FirstEV
Sweden
Many dealers do not choose to send a ticket to Germany, either due to laziness or because they believe they already know the answer. Have they actually sent anything to PAG for confirmation?
The main reason they can’t replace anything prior to approval is that most parts are not kept locally and sometimes need to be shipped from Germany. Secondly, they wait for approval because otherwise they will not get paid for the spare part or the labour. Warranty guarantees that they are fully compensated for everything, including diagnostics.
Yes, it is true that Porsche keeps diagnostics to themselves, as anyone would, since these are trade secrets and service centers are technically third parties. That being said, it doesn’t really matter in practice, because Porsche will still make a decision based on the data, so you will receive a solution either way.
EVowner
Macan 4s
While I could probably agree that they were lazy and dismissive in the begining I somehow doubt that they are not paying attention now as we are at point where made it very clear that if everything is not fixed this time I want my money back and then it is them who will be stuck with this "marvel of german engineering". Hence them trying to blame PPF to have at least something to show me that it is my fault that blind spot monitor is crazy.
I honestly cant agree with your interpretation of Porsche keeping 60%+ of diagnostic data to themselves. If this was disclossed openly by sales people who must know, because service centers are part of dealerships, many potential customers would walk away, because other brands dont do this to this insame extent.
Believing that manufacturer cares if you as owner is happy with their car once it is sold and will at their expense disclose and fix every non mass lawsuit treathening issue in this day and age of corporate greed is laughable idea. Thats why normally it is dealership service centers that can see issues in diagnostics that try to proactively fix them. Again not because they care if you are happy owner, but because they understand that pissed customer will not come back to buy another car from them or if they wont be able to fix the car it will be them who will be stuck with it in the end.
