Bose upgrade - no more boombox
btMacan
Bruce
New England
macan4
Every Porsche forum seems to have number of threads about people being disappointed with the Bose sound system upgrade while not wanting to fork over another 4k for the Bermester. Fortunately these communities have found a way to close the gap or exceed what the factory offers. Since the Macan EV is a clean sheet it wasn’t clear how to apply the same logic to this vehicle. I was chatted with the guys at Rennspec.com regarding my 718 and they informed me that the same Bermester tweeter upgrade for the 718 should work with the Macan EV also - that got the ball rolling – then they recommended trying the same sub upgrade folks are using in the ICE Macan. I thought I might need a more powerful sub amp but the Bose amp does fine. Results were great with a spend of about $600.00. Please see attached for the details.
ckfilm
Christopher
La Quinta
Macan EV Turbo
Thank you very much on the details of the equipment and on the install instructions. I'll certainly consider this... in particular with the sub-woofer / base unit, which on the Bose system is pretty thin.
MaccaMark
Really useful and informative. Thank you for sharing.
Totally agree that the Bose “upgrade” is disappointing. Not sure I’m brave enough to do the tweeters though!
seraphmoss
Hannah
I don’t mind the twitters and mods on my Bose but the sub is really disappointing compared to my previous ICE Macan’s Bose. I’m going to get the sub you recommended.
Did you have to do anything other than replace the sub e.g. power, resistors or anything else?
btMacan
Bruce
New England
macan4
The sub is super easy once you have the wiring harness - no resistor needed just a couple short pieces of speaker wire, once you cut two little locator taps on the box you just need to rotate the new woofer to align with the factory.screw locations. I only managed to get 4 holes to align but it’s solidly mounted. Best $250 you’ll ever spend :)
verdee
Evan
denver
macan 4
For the tweeters did you buy the adapter cable with or without the crossover?
btMacan
Bruce
New England
macan4
I bought the adapter cables and tweeters from Renspec. The Bose amp has an active high-pass crossover for the tweeters so no need for an extra capacitor
Pepppie
Rotterdam
Porsche Macan
Have you got a link to the exact adapter cables you used?
And maybe the exact tweeters (you wrote 1" Burmester) and center speaker (I can't find the AF 3.5 speaker)? Thanks in advance!!
TypeMRT
Maurice
Washington, DC
Porsche Macan Turbo Electric
Thanks for the write-up on installation. I’m going to go for the sub upgrade but have a couple of basic questions first that’ll help keep this from turning into a half-day project:
1. How do you remove the tailgate trim?
2. What’s you’re recommendation for speaker wire?
Pepppie
Rotterdam
Porsche Macan
Here is what I ordered from Rennspec:
Have you got a picture of the adapter cable for the sub? I contacted Rennspec and ordering from Europe is hard / expensive. I want to try to create my own cable.
Thanks in advance!
btMacan
Bruce
New England
macan4
The factory connector has 2 male spade on the end that connects to the woofer - you could build a simple cable with 2 female spades easily enough
seraphmoss
Hannah
Woofer has arrived, now for the hard (and fun) part.
