CarPlay Apple Maps spoken directions + Music
jkickz
Tesla Model 3, Tesla Model Y, Porsche Macan
When using Apple Maps via CarPlay, I am noticing that the music audio volume goes down abruptly to have the spoken directions come through. When using the PCM navigation, it doesn’t seem to do this.
Is there a way in the settings to make it so that the music isn’t turned down?
Sometimes the music doesn't return.... but that seems to depend on the source.
jm1883
James
Manchester, UK
Does anyone else have an issue with the Nav volume being much quieter on Apple Maps? I turn it up, but then it makes the Porsche Nav’s announcements about traffic etc. extremely loud and you can’t turn those off.
benl
Ben
Melbourne
Macan Turbo EV
I also found the CarPlay Apple Maps spoken directions are very intrusive when listening to music. It fades the music way too much and I can’t find any setting to adjust it like I can with my other vehicles. I hope this can be changed in future iOS or PCM software updates ??
Dunno if this helps, I typically don't use spoken guidance.
For most cars, you adjust alert and message volume only while the alert/message is playing.
You can adjust spoken guidance on the iPhone. The steps depend on iOS but you need to be routing when adjusting.
iOS18:
Change the volume for spoken directions
You can change the default volume for spoken directions while following them.
  1. Go to the Maps app
    Electric Macan EV CarPlay Apple Maps spoken directions + Music 2d0b2b0e721e8078455f9b089e5d81b2
    on your iPhone.
  2. Get driving, cycling, or walking directions, then tap the Go button to begin following them.
  3. Tap
    Electric Macan EV CarPlay Apple Maps spoken directions + Music a1ce61b5b38b4033a2f2e2a853f3b796
    , tap Voice Volume, then choose Softer or Louder.
Tip: You can also change the default volume in Settings
Electric Macan EV CarPlay Apple Maps spoken directions + Music 88b2400e45bcf521514b7252cbb2d959
> Apps > Maps. Tap Spoken Directions, then choose an option below Voice Volume.
There is also some sdjustment for intrusion.
I believe Android phones are similar.
I notice what I think are other iPhone apps interfering with the Radio. For example, after a phone call ring it will sometimes return to apple music instead of the radio station. Doesn't seem to happen when I close the music app.
jm1883
James
Manchester, UK
iOS18:
    on your iPhone.
  3. Tap
thank you! This solved my problem
Macan 4, Macan 4
The Porsche guidance announcements were too quiet for me. I inadvertently turned up the volume while one was playing and that fixed the problem. YMMV.
