Is the “Coming/leaving home light function” standard on the Turbo?
masmole
Chicago
or do you really have to order the $890 Glacier blue or Black light strip option just to get the coming/leaving home light animation?
It’s a bit confusing to me because while this option description highlights this animated light functionality for coming/leaving home, it also says “Note: Identical form and function to standard taillights” which to me suggests the same coming/leaving home functionality with only difference being the blue or black color of the PORSCHE lettering on the light strip.
You may be confusing two different functions:
One is just your usual Coming Home function that is standard (translation is not great):
Electric Macan EV Is the “Coming/leaving home light function” standard on the Turbo? 1737077916025-24
Electric Macan EV Is the “Coming/leaving home light function” standard on the Turbo? 1737077947895-p4
The other function is animation of the light bar that is only available if you upgrade to Black or Glacier, that is in addition to the above lights on for a period of time standard function.
masmole
Chicago
What adds to the confusion for me is that the Turbo already comes with black PORSCHE lettering on the light strip as standard. So instead of the option being named “Light Strip with PORSCHE Logo in Black $890” I feel it should be named “Coming/Leaving light strip animation…” because that’s the real differentiator and the only differentiator if you choose the black one for a Turbo build.
Anyhow, thanks for clearing that up. I will make sure to check that box on my build.
I agree, it is confusing, but these are 2 separate things if you dig into it.
Porsche logo in Black is standard on a Turbo, which is just the text, but no other modification to the light bar itself.
However, what you are paying Exclusive Mfg department $890 for is the Circuit board graphics inside the light in Black and that animation.
Electric Macan EV Is the “Coming/leaving home light function” standard on the Turbo? 1737081431843-yz
Coming home function is standard on all Porsches.
The option for animation on the rear light bar comes when you option the rear illuminated logo.
