Mobile charger fitted with a UK domestic 3-pin plug
Jonny McCann
Jonny
Cheshire, UK
Macan 4 Electric
I'm looking to purchase a mobile charger for my Macan 4 just in case my wall charger ever plays up.
The Porsche Mobile Charger looks decent, and claims 'up to 7.2 kWh', but costs £1,131.
I've seen Macan 2.3 kWh chargers fitted with domestic 3-pin plugs (and 5 m cable) from a specialist, UK-based supplier (EV Extras) for £130.
As this would be used exclusively in emergency situations, Is there a compelling reason to consider paying nearly 9 times as much for the higher-spec. Porsche-branded product?
13A 3 pin plug will provide glacially slow charging speeds (0.1 mile / minute) and you'd only ever use in a dire emergency.
Better to have the option of a 32A tail along with the 13A option.
Any EVSE which provides both will suffice IMHO.
Jonny McCann
Jonny
Cheshire, UK
Macan 4 Electric
Many thanks for your advice.
I do have a Hypervolt wall charger at home, so the mobile one would indeed be for emergencies.
andics
Taycan 4S Sport Turismo MY24, Macan 4S MY25
You only get 2.3kw/h with the Porsche one on a 3-pin plug, so for that purpose the cheaper one would do the same.
If you upgrade the home plugs to a 32A the mobile charger is definitely capable of reaching 7Kw/h (I do use the one from the taycan on the macan at that speed on a daily basis)
Jonny McCann
Jonny
Cheshire, UK
Macan 4 Electric
That's great. Many thanks.
