Passenger mirror keeps moving position
taycanstuff
Ice Grey 4S
Hi All,
I have the passenger side mirror tilt to help with reverse parking - however I have noticed it doesn't always reset back to the driving position.
Number of times I've wondered why the passenger mirror is pointing too high, seems to happen after I reverse and parked, then on the next drive the passenger window is off.
I've had to either manually adjust it back or I've found today that I need to press the memory seat button that it was set to reset it.
Anyone noticed this or is there a fix?
Cheers
llindenb
Larry
United States
2025 Macan Electric 4S
Interestingly, I’ve had the same issue intermittently with the drivers side mirror. Essentially identical. It has not occurred in a few weeks and I would say it has only occurred after the mirrors were folded in for some reason (so I’ve stopped doing that at all).
taycanstuff
taycanstuff
Ice Grey 4S
UK based so your drivers is our passenger, maybe same issue - endless little issues....
SuperH
Helen
Walsall, West Midlands
I've had the same issue a few times. I'm now wondering if it only occurs when I've reversed then turned the car off to put it into park, rather than putting it into park then exiting the vehicle to turn the car off, which would make sense I guess as the car hasn't had a standard prompt to say reversing has finished (so put the mirror back up) before it all gets shut down. Hmmm - I'll have to test it out and post my findings!
taycanstuff
taycanstuff
Ice Grey 4S
Let us know how your testing goes, I found my mirror was pointing up towards the sky, whereas I thought it would be pointing too low if it was the parking not had time to re-adjust. ?‍♂
SuperH
Helen
Unless it thinks your normal is actually the dipped position, so then over compensates because it moves it up?
taycanstuff
taycanstuff
Ice Grey 4S
Possibly the system is fooled into thinking it needs to be in a different position. Guess I could turn the mirror function off but it does help when reversing and watching those kerbs and alloys...
taycanstuff
taycanstuff
Ice Grey 4S
I thought this was fixed as it was working for the last few weeks - but the car has a life of it's own, now every time after reversing the passenger mirror reverts to a position which is pointing too far up so doesn't appear to be the case that it hasn't had time to reset....every time I get in the vehicle after a reverse I need to set my mirrors - tried the memory seat function to save everything again but no dice.... :(
