Porsche APP working with Non Porsche home chargers
castlg
Gary
Westhampton
2025 Macan EV 4S
Does the Porsche app work with a ChargePoint home charger?
It works very well with my UK Simpson home charger so I’m sure it will work with a ChargePoint one. In my case, I have to let the App / car control timed charging - using the Simpson charger App didn’t work. I have an EV rate from midnight until 7am so I set the departure for 7am and ensure the required charge isn’t any more than 49kw as otherwise it will start before midnight.
what do you mean "work" - all North American EV's conform to a published standard for home charging - it's expected (and commonly the case) that your Macan EV will work just fine with _ANY_ J-1772 standard EVSE (EV Charger)
if you're referring to controlling the EV charger via the app - that's not the EV charger any ways - as the Car not the EVSE is in control of the charging session - the EVSE is just a gloried extension-cord/on-off-switch - the car does all the heavy lifting and doesn't care what vendor of J-1772 charger it's plugged into…
so what aspect of the "app" are you referring to as "working"? I can't answer that as your question is too vague
but will your Macan charge with any EVSE - the answer is 99.9% probably and you'l be able to start/stop the charging via the app because that was never the EVSE anyways.
CraigW1
Los Angeles
2019 Porsche 911 GTS, 2024 Macan 4
Assuming your question is can you track the state of charge and estimated time to reach your target SOC on the My Porsche app, the answer is yes.
robskier
Rob
colorado
macan 4
I have a charge point home charger. The home charger works great. You can track the amount of charge on either the Porsche app or charge point app. The car charges to what the car is set to charge to. My plug and charge part of the app is still not functioning so I don’t know when Porsche will solve that. But the charge point home charger works great.
