Tried super charging multiple times could not get past 40kw anymore
mlarco52
canada
macan ev turbo
Cannot get past 40kw charging speed at super chargers. Sometimes got 34-40 kw max speeds. I did reset the profile in the pcm once but redid it just fine everything else works perfectly. Truck is up to date also. Before previously two times I had charged it twice once at electrify America and another at tesla and both times got speeds of 150-200kw.
Was there a update that glitched the charging speeds?
Battery is at 21 degrees Celsius before charging each time.
Truck has been driven at least a hour each time before almost always in sport plus
Didn't input in porsche app or navigation directions to charger just drove there
Tried electrify chargwrs 2 different locations and tesla also.
Stuart
Stuart
Amsterdam
Have you tried using the porsche Nav app, as I suspect the battery is not at the optimum temperature for high speed charging. I have a MY26 Macan which shows on the side of the battery guage the instant max charge rate and at normal temps you will get low charge rate, for fast charge it will need to be around 43c please see pictures below
Electric Macan EV Tried super charging multiple times could not get past 40kw anymore charge 2
Battery temp was reported as 21c, which is a little below the optimum starting temp for charging, but not enough to drop speed to only 40kw.
That first photo clearly shows a max charge speed higher than 40 at a much lower temperature than 21c
This low speed is a common problem reported by several people in the post I linked to
Notice that the second photo above with the battery temperature shows the range (gray bar on the right of the dial) starting MUCH lower than 43c and that temperature is NOT the optimum temperature for starting a charging session. This range starts about 25c. 43c is a mid-charge temperature that is expected as power is stored in the battery
mlarco52
canada
macan ev turbo
I've been getting horrible range also from 80-15% I would get 120kms with spirited driving. Wasn't the case before. I haven't ever charged the vehicle to 100% so today I am attempting to rebalance the bms.
Got the soc to 18-19% let it sit overnight woke up vehicle showed 26% which I'm assuming is the bms recalculation of what the battery level was overnight. Now since it's sat for 8 hours plugged the vehicle in on my home level 2 charger and charging to 100% then will let it sit overnight. Hopefully this stabilizes the battery back to normal as it has for others.
Art
Arto
Finland
T 4S, 997 C4, Willys MB, 628 CSiA, ST4S, 750 Paso
Driving Macan 4 below 20% and letting it heat to ca. 35 C the charging was way faster than in my 4s 2020.
I only had the car as a loaner for ca. 1000 km but battery handling was way better than in my Trashcan.
What did your charger report? Was it limited by car?
Electric Macan EV Tried super charging multiple times could not get past 40kw anymore Screenshot_20260315_154327_com.opera.browser
