- First Name
- shawn
- Jan 11, 2024
- Canada
- Macan 4, Model Y, Model 3, XC 40 Recharge, Leaf
Also to my surprise one is reporting that 14 way with massage may be more comfortable than 14 way without..maybe because of the bladder. Would love for someone to test thatI have the 4 and really like it. If you don't really want the torque vector feature then the 4 trades a little in power but you gain in range and the Rear Axle steering is a great feature to keep. The 4 is fast enough for me hence I went for the Macan 4 for the extra range. This build is solid. Only think I would suggest is maybe getting the side trim in painted your external color or gloss black or carbon fiber. The standard blade looks a bit plastic to me (which is why I am actually changing it to external color blades). Note that if you get the standard blade you cannot wrap it as it has a bumpy surface so that is what you get. Looks like you are going with the 14 way seats in this instead of the 18 way. If that is your preference then it now opens up the possibility to get the massage function (if that is interesting to you). Cheers.
