- First Name
- David
- Jan 28, 2019
- Santa Cruz
easy one network most works most of the timeCan someone please explain the error in my thinking that Tesla Superchargers are the most hyped and least powerful chargers of the modern set of DCFC CPOs?
1. V3 cabinets (500VDC max) are 360kW shared across 4 units with potential site DC bus bar but still it’s 90kW per vehicle if fully occupied and 180 at 50%. Tesla have a fairly poor charging curve and thus these restrictions are not so noticed. Now, with other vehicles, charging there that have substantially more robustness to absorb power, these limitations will be very visible.
2. The elusive V4 cabinets (1000VDC max) are 1MW shared across 8 chargers (1.2mW for truck stations). They don’t support a DC bus bar thus each set of 8 will derate to 125kW if fully utilized.
3. The one and only V4 site in Redwood City still has dispensers covered up, theoretically to limit the potential derating. Also, I don’t foresee Tesla wanting to spend so much money upgrading their chargers to 1000 V when the only vehicle they sell that would be enhanced by. This is the cyber truck which has very limited sales. And with their amperage boost on V4 dispenser is on the three cabinets to 325 kW I feel they may see the problem as already solved for their ecosystem.
4. Handle overheating and derating is still an issue. Even on the latest Easter Edge race by Out of Spec they were poring water on handles. I do think non-Tesla suppliers of J3400 handles may have solved the cooling issues. To be seen on IONNA charging a 500+Amp NACS/J3400 vehicle that has a good curve.
the other networks don't
the spec's dont' matter if the charging stall is broken or can't activate a session or you have to wait because of congestion - and there is often "enhanced" congestion - i.e. you wouldn't have had to wait for open stall if all the stalls were actually operational…
also you rarely if ever get the the actual max charge rate at the 800V stations - I can count on 2 hands the number of times I've actually experienced a true optimal 800V session - the vast majority of my charging session meander around the 150 kW rate or less due to a large number of variables…
you're focusing on theory - others are focusing on actual experienceI've owned an 800V EV since July of 2020 - I've gotten a charge rate of over 150 kW less than 10 times in well over 150 charging session - but I've gotten 0 kW charge rate at many many CCS stations that simply were non-operational…the CCS stations fail to operate entirely much much more often than they provide an enhanced charging speed…
the supercharger network provably scales and offers a better experience than a non-operational congested CCS stations with 2 of 6 stalls actually operational…
also the performance "advantage" of the 800V stations is completely lost if you have _ONE_ technical hicup - its very very very easy to lose 5-6 minutes fussing with what turns out to be a non-operational station…or setting up an account or having a charge not go through - or having a session timeout while trying to handshake - or simply moving the car to another stall…
the performance advantage of 800V stations is more perishable than the freshest of strawberry's - you have about a 10 minute window where the 800V session will be 'faster' than 400V stations - after that both types of stations offer similar if not identical charging speeds…and if you pull in at 30% SOC or above that window is even smaller…or your battery is at the wrong temp - or the stations is balanced…
800V stations have _ONE_ shot to offer an actual faster charging stop than 400V stations - the conditions for success are narrow and fraught with incompetence and enviromental conditions outside of your control…if you have to take a mulligan on an 800V charging session you've already lost in terms of over actual time spent stopped trying to charge an EV.
if you're pulling into a station at 40% or above SOC - there is _NO_ advantage in terms of charging speed - and I've seen many many EV owners do this…
the conditions for 800V charging to actually be "faster" are narrow, difficult to achieve, fleeting, and easily derailed.
the criteria for success must be measured in terms of: total # of times plugged into a 800V charging stalls - total # of times you actually achieved a "faster" charge rate…
i've done two road trips with my 2024 Macan EV - both published with data on this forum
- Nov. 2024 - 800V "success" rate - 20% "faster" - 80% normal or slower - 20 charging trials
- July 2025 - 800V "success" rate - 0% faster - 100% normal or slower - 10 charging trial
4 /30 = 13% - 87% of the time the 800V CCS stations was no faster than supercharging
but that stat above do NOT include the CCS flaky-ness factor or the number of outraight failures of a given CCS stall/station being non-operational - which would make the "success" rate even less impressive.
consistent mediocrity beats flaky performance every time…
