Air suspension - right height automatically changing based on driving speed?
strwbryfruitcake
Did a search, didn't find anything. Macan 4S us spec with rear steer if it matters.
I noticed lately that the ride height of the car will change automatically between lowered and low at higher speeds?
I normally drive in normal mode with lowered right height, but sometimes I notice if I go 90mph+ for more than a short distance, the car will drop to the lowest setting (low), and when I exit the freeway to surface street speeds, it goes back to my set setting of lowered?
thanks in advance
thanks in advance
just like how the spoiler deploys at different heights depending on the speed, the ride height is adjusted automatically depending on the speed... all for safety and aerodynamics
thanks in advance
All part of PASM - chassis and shock absorbers. Search Owner's manual for a full overview.
RAS doesn't impact the function or feature set.
Auto height adjustment commences when travelling at 4mph or higher.
6 levels available depending on use case.
