Avoiding login when starting?
FĂ©lix
Cádiz (Spain)
Hi all, does someone know how to avoid having to log in when starting the Macan? Thx in advance
I believe you might have the glitch when the car setup didn't work perfectly the first time, usually due to a spotty connection. Is it asking you to login every time you start the car and other small glitches?
A factory reset will fix this. I forget which screen exactly, but somewhere in settings you can do a "Factory Reset". It takes about 5-10 minutes to do the reset & setup. You will lose any saved settings.
Great_Cookie
Malaysia
Nil - Macan 4 EV (Nov '24 Production)
Alternatively, if you're talking about having to enter a PIN code every time you start vehicle then it could just be that you have to disable "Access Protection" to "No Access Protection".
Electric Macan EV Avoiding login when starting? 1736437999405-s1
Screenshot Credit from YT Video here (3min 54sec): Comprehensive Porsche Macan Electric Set Up
