Destination SoC estimate going bananas
chrisk
2025 Macan Electric Turbo
My Navigation believes I will arrive at my destination with +24% SoC than my current SoC. When I started the trip my SOC was under 70% so I have no idea how PCM comes up with this crazy eatimate. This new software bug started yesterday, until then the estimate was more realistic. PCM reset or leaving the car locked and parked for hours does not fix the issue.
My passenger captured this video showing my current SoC at 62% and the navigation showing I will arrive with 86%!!!
chrisk
chrisk
Doesn’t it include a charging stop?
It seems to show one on the right of the screen.
It shows there is a EA DC charger on the way but the navigation does not route to it and why would it even make a charging stop when I can get to my destination with >60%.
Btw, same problem even if there is no DC charger on the way or nearby.
charging stops can be added manually. definitely it does not show „chargers on the way“. your screen would be full..
john
Dallas. Tx
A couple days ago I had something similar. Showing an arrival SOC that couldn’t be possible. On investigation , I discovered that there was a charging stop programmed and the arrival SOC Then made sense. But, the intermediate stop wasn’t readily apparent on the map. You had to look at the overview screen.
chrisk
chrisk
In US it shows the Electrify America DC fast chargers
chrisk
chrisk
Here is another video that shows the crazy arrival SoC without any charging stops or any nearby chargers. I just set a destination two miles away to test. My SoC was 57% and the car estimated I will arrive at 82%!!! No intermediate stop.
castlg
Gary
Westhampton
2025 Macan EV 4S
Please check your charge settings. I keep my arrival SOC at 5 or 10% otherwise it automatically puts in a charge stop and adjusts the arrival SOC accordingly.
chrisk
chrisk
My arrival SoC is set at 10% so that is not the issue. I also check the route plan and there is no charging stop. See my previous video where I chose a destination only 1.8miles away, still same issue.
