- First Name
- Tomek
- Sep 28, 2024
- Poland
- Macan 4
Hi, my car was often leaning to the right since delivery day.
After 5-6k kms my dealer did full suspension geometry (you can do that under warranty up to 10k kms).
It showed some red values before (out of factory) and all green after.
The car was super stable after that and I think the consumption was a bit better.
However... the steering wheel was left off center, meaning it was slightly turned when driving straight.
I went to correct this, they lifted the car and adjusted something manually without re-doing the geometry.
The steering wheel was centered but the car started leaning to the right.
So they did a reset of "steering wheel angle sensor" - whatever that is, it was off by 0,5 deg.
After this the steering wheel is center and the car does not lean to the right.
However... it does not keep a straight line as it used to and require some minor wheel adjustments.
It's very very subtle and it's hard to detect during city driving but becomes noticeable at higher speeds.
Is it possible that centering the steering wheel this way changed the geometry, should I insist on redoing it? What's this steering wheel angle sensor, at first they did not reset it and were surprised it's required.
Problem is it's very subtle and a lot of this process is left to driver's impressions (like is the wheel centered or not? does the car lean or not? it could be windy, the road is not leveled, some effects you notice only driving 140km/h on highway etc). The dealer is helpful but I get the impression they don't see the problem. What i'm thinking is perhaps due to the weight of the car it's more susceptible to these issues and test driving it for 5 mins on city roads during traffic is not conclusive.
