Range in Macan Turbo
I got 156 miles with 4 miles left driving at average of 57 mph.​
That doesn't match my experience. I get almost 250 miles going up to 75 mph.
I wonder what's different?
MaccyT
Maarten
Netherlands
Macan Turbo / Audi Q3 TFSIe
I had to charge three times because there was no charge left after starting off at 100%. I got 156 miles with 4 miles left driving at average of 57 mph.
I then charged 100% and I managed to get 180 miles with 7 miles left.
the third charge was at Porsche Cambridge.
I certainly do not drive fast.
Craig.
If you get those results I would definitely stop by a service center. Since you also got a red circle I would let them check the HVAC components. Seems like something is draining energy and numbers that high are almost only possible by the HVAC system or engine(s)/battery issues.
Went to some friends yesterday so mine did a couple of launches ;) but now at 372km(231 miles) at 84% .
Electric Macan EV Range in Macan Turbo IMG_7793
MaccyT
Maarten
Netherlands
Got a long trip today and started at 95% charge. Did Dutch highways a lot which is 100km/h during the day (62 Miles) and did 355km (220miles) and had 7% left (35km, 22 miles ) and started charging at 272kW till around 30% and after that could make my way home.
Around 6 degrees Celsius on average with mild winds and the 22” Spyders.
Electric Macan EV Range in Macan Turbo IMG_7797
So basically 240miles was possible on a 95% charge today.
Macan 4, Macan 4
Just a data point on wheels. I have two Macan 4, one on 20 inch aero wheels and one on 22 inch Macan Sport Wheels. With the 20 inch, over 15,000 miles, I have seen 3.1 miles / kWh. With the 22, over 6,000 miles, it is 3.2 miles / kWh. I drive the former, occasionally with a bike rack. My wife is a calmer, slower driver in the latter. So it seems that driving style overshadows the wheel size, but her number of 3.2 certainly would be higher on 20’s.
MaccyT
Maarten
Netherlands
Hello macaners!any idea about the range of the basic macan ?
That is the good thing, you can expect at least the numbers you see here! Probably 30-50miles more depending on your wheel choice and 4/S/GTS choice.
And looking at your location, bear in mind that currently in The Netherlands it’s cold and wet. So that reduces the range by another 15-20% .
I’m expecting a good 430km in the summer weather with a “normal” right foot in my Turbo.
MMR
Electric Macan EV Range in Macan Turbo IMG_9246
My first 1000 miles has given me this
(22” Spyders, usually on Normal, rarely on regen, in British winter)
MaccyT
Maarten
Netherlands
Had another long trip and got another nice result.
Got 360km (225miles) on a 90% charge while it was averaging 3 degrees celcius sunny weather with cabin temp at 21,5 degrees celcius and Seat heating on 1. Average speed was 87km/h or 54miles per hour. Cruise set on 110km/h which is 68miles per hour.
Average consumption at 21,8kWh/100km or 2,74mi/kWh . Which is absolutely superb compared to my previous E-tron 55!
Can’t wait for the summer. Definitely 300miles will be possible without too much hustle.
It’s also fun to hit the pedal of course so this will probably not be my daily consumption but nice to know what is possible.
racerjim
Jim
Canonsburg, PA
2024 Mercedes Benz GLC300
Thank you for the report! I'm getting 2.2-2.5 mi/kWh in drives at 70mph at slighly colder weather, around 1C.
actuario
Spain Malaga
MACAN EV
Thanks a lot, I have ordered a basic Macan EV 20 wheels ans I expect to range 500 kilometros.
Is this realistic ? what do you think ?
I live in Malaga, Spain, from 30 to 8 degrees, with an average of 20.
warm regards
MaccyT
Maarten
Netherlands
warm regards
500 will be a challenge but you can get close I guess. Don’t forget to put your regen on as around Malaga there are a lot of height differences as well. The weather is much better there compared to my living location and you get the regular 4 with the more efficient wheels so take care of your right foot and you can get close I think. By the way, nice area, I own an apartment around Rincón ;) .
warm regards
Normal driving, easy ... ideaal conditions 20 inch 4 ... I get that sometimes in summer on 20's in my Turbo driving normal I average 18.5kwh / 100km from April till September good for 480 km's ...
warm regards
Base model has best wheel size, single motor and lighter.
95 kwh usable power from the battery would see 285 miles if your efficiency was around 3 miles / kwh - 458 kilometres.
500 kilometres will be a challenge but if your efficency is better then possibly.
