Ride Height Control
MaccaMark
Mark
Hi Folks, question regarding ride height.
I drive mostly in normal mode with lowered (not lowest) ride height.
All is good with ride and handling even on our shockingly poor UK roads but if I flip to Sport mode for a rare bit of fun, when I return to Nomal mode my ride height resets to normal too.
is it possible to set the default ride height to Lowered in Normal mode or is this a life sentence of having to adjust manually if every time I venture outside Normal?
any insight welcomed.
2024 Turbo.
correct. Normal is not modifiable and saved... If you modify normal ride height, it will stay at that ride height unless you change it or the mode.
once you go back to normal, the settings will be as default for for normal (normal height) and stay, until you change them...
so what can do, is modify one of the other modes to the height/damping you like and just toggle to that mode every time...
otherwise, what i do, and what i learned from others...i just keep it normal, lower the height...it'll stay lowered in "normal" forever. If you change damping, it will not stay however. that will return to normal each time the car is started
JonnyDW
Jonathan
Hampshire, UK
That’s what I do … have Sport setup as my usual driving, then Sports Plus for the maximum sporty drive (for me). I did this mostly because I prefer the throttle response in Sport.
Reactions: aks
