Is it possible to power things in my house with the Macan in case of power outage?
quaxon
San Francsico
I would just really want to power my router and modem which are in the garage right next to where it is parked, how would I go about doing this? I have heard other EV's are able to power appliances and a bunch of other stuff when the power goes out. This is my first EV so completely new to all this.
fubar.droid
It does not have V2L so you can't directly but I believe the AC outlet option provides 150W, which you could use to power a router and modem.
You could also connect directly into the 12V and probably get much more out of it, like 500W, but I have no idea if the traction battery will keep it charged automatically when the 12V is getting drained and you are not plugged in to a wall connector (which obv won't work during a power outage). Some cars do and some don't and no idea if Macan specifically does.
What I'm planning to do is get like a 2kWh battery like an Ecoflow and then use that to power my fridge and anything else during a power outage and use the Macan to charge the Ecoflow battery.
For the general case, the Macan won't be able to 'power your house'.
However, if you option the power outlet in the trunk, you'll have the ability to plug things in up to 150w, which might be enough to run your network hardware. My Eero Max 7 uses almost 22w, my cable modem may use about the same, so both could be powered with some left over to plug in a charger for your phone (although there are also USB-C and 12v power options for that type of device)
answer is yes and no - there is an optional AC outlet in the trunk area but only for 100watts of less so not a lot of power there...
the "best" way to power your home from an eV is with a 12V inverter clamped directly to the 12V battery - and then leave the car on - the "big" battery will charge the "small" battery and you can power some stuff
something like this could do the trick
https://www.amazon.com/Maxpart-Inve...89049&sprefix=12v+inverte,aps,206&sr=8-7&th=1
but this is a YMMV situation and different EV's will respond differently to being used like this - so while this is feasible it's not recommended…
but yeah you can power your home from an EV or ICE vehicle if you're willing to work with a 12V inverter…but it's not ideal and may have unintended side effects....
the best solution is a Solar/Battery system and that "just works" and is a great solution.
RunningOnSolar
Scott
Ohio
Macan 4, Subaru Solterra
A sufficient solar + battery solution is ideal for powering your house and charging your car. There are several caveats here. Such a solution is more effective in summer than winter and also in sunny weather. Overcast and rainy, especially in winter, not so much. Hopefully those who have adequate sun and solar sight lines consider at least some investigation. When you’re on the road some charging stations leverage solar as well.
I optioned the outlet as part of my Macan’s Swiss Army Knife config philosophy, but also realize its limitations.
