Home charger best recommendations?
adamjay79
Adam
Krystal0821
MacanEV Turbo on order
Migrating from our Tesla Highland Performance to a MacanEV Turbo and am super-excited. Curious which wall charger you all use... did you go with Porsche or something like ChargePoint?
tesla tap and you can use your tesla charger no problem
if you want a wall mount the tesla universal wall charger is pretty awesome- just-1772 and nacs plugs built in
adamjay79
adamjay79
Adam
Krystal0821
I have the Tesla newest model wall charger - but no adapters. Do the adapters not slow it down?
verdee
Evan
denver
macan 4
I have a Tesla wall charger and bought an adapter from Amazon works great so far. I didn’t want to change the entire charger as it seems most brands are moving to NACS in the future
the adapter is just pass through - full speed charging - it just works!
the amp rating on the adapters is a measure of robustness (how much they can handle without melting) - not a restriction of max charge rate
you can use a 40 amp TeslaTap with an 80 amp Tesla Charger - but the adapter may fail under the load!
this is the "kit" you want to order
You can post that you contacted us and we will have a COMBO kit available later today.
https://www.teslatapinc.com/index.php?route=product/product&path=59&product_id=60
The combo kit will include:
1 X SuperTap
1 X SuperTap Case
1 X TeslaTap MINI 80
1 X TeslaTap MINI storage pouch.
it will set you up for NACS charing for your J-1772/CCS1 Macan - superchargers are not yet "open" to Macan - but they will be - and the kit for the two adatpers does have a cost savings!
adamjay79
adamjay79
Adam
Krystal0821
Thanks - although according to the site this won't work with my wall charger:
"This adapter is NOT COMPATIBLE with Tesla Destination, UMC, or Wall Connector."
that’s just the ccs1 adapter - there are two separate adapters - one for tesla slow chargers and another one for superchargers - you can purchase both
MFitz
Michigan
Macan 4S PS88FTV9
Agree, I have a TeslaTap for my Tesla charger and it is a very solid unit. I did not want to buy another charger after dumping my Tesla and I am very happy I just bought the TeslaTap.
loid55
New York
Taycan GTS 2022
Late to this thread, but for anyone still deciding on a home charger for their Macan EV, don't overthink the charger brand too much. I went with a ChargePoint Home Flex, but the Tesla Universal Connector is also solid.
The more important decision is who installs it. I hired Wolf River Electric to run a 60A circuit and hardwire a 48A charger. They knew EV load calculations, didn't use subcontractors for the wiring, and handled the permit. That gave me peace of mind.
Also, check if your utility has a lower overnight rate. Mine is $0.06/kWh from midnight to 6am, so my cost to charge from 20% to 80% is only about $4. Much better than trickle charging on a 110V outlet.
