Voice Select app
I was looking through the App Center and I saw the app Voice Select which offered an update. I did the update.
I then looked for the App on the menu, and it did not appear. Long story short, it turns out to use the app, you need to either activate it (Hey Porsche, Activate Voice Select) or go to the Settings/Accessibility menu.
The purpose of this app is to operate functions that appear on the PCM by voice. It assigns a number to each icon button on the screen, and then theoretically you can say (e.g.) "Tap 4" and it will activate the icon labeled #4. You can also say "Swipe Left", (or right or up or down). Unfortunately, it seems a bit buggy (doesn't always respond), and it apparently deactivates the Voice Assistant. It also tends to hide the icons behind the number labels.
It's too bad, because in principal it allows you to control the PCM touch screen in a less distracting way. I'd love to see this app improved and integrated directly into Voice Control. I had a little trouble figuring out how to deactivate it again also (I had activated it by voice, but apparently you can only deactivate it by finding it on the Accessibility menu and switching it off, because it doesn't seem able to shut itself off and it kills Voice Control) All in all, I feel like this app is in an early beta testing state and is more annoying than helpful as a result.
I did a Google search and a site search and nothing. Does anyone know more about this app?
Electric Macan EV Voice Select app Accessibility Menu
Electric Macan EV Voice Select app Voice Select
Updated the Voice Control this evening but can’t find out how to use it. Tomorrow I will look at it. ?
Tried to find a way to use Voice to select area/button on the screen but can0t find any....
Quoting myself above:
Here is the Voice Select toggle on the Settings/Accessibility menu:
Electric Macan EV Voice Select app 1733361191092-78
Thanks @dgkhn but I can’t find this menu.
Hmmm. I'll make sure I have the right path when I get a chance. You could try Hey Porsche, "Activate Voice Select" but not a very good idea if you can't find the menu, because then you wouldn't be able to shut it off again, and I don't think you'll want to keep it in its current state.
1. Settings button from app menu screen (not from gear).
2. Scroll down to Accessibility.
3. Scroll down to Voice Select.
