Will winter wheels & tyres TPMS from Taycan Cross Turismo work on Macan 4EV?
soundman
Rob
Scotland
Macan 4 EV
Fitted the winter wheels and tyres from our Taycan onto the new Macan 4 EV and it won’t communicate with the TOMS sensors. It goes through the calibration procedure but never hooks up even after 50 miles. Visied the local Porsche dealer for help and after much head scratching they informed that the Macan has a totally different system to the Taycan. I then contacted a TPMS specialist supplier who told me that if there was a new TPMS system they would know about. Who do you think is correct?
nischalr
Ft. Lauderdale, FL USA
I am sorry that I do not have any information about the TPMS, but I am very interested to know about the fitment of the Taycan wheels on the Macan. Any fitment issues? It seems the spec of the Taycan and Macan have a slightly different hub bore 71.5 mm vs 71.6mm, but identical bolt pattern. Likely negligible difference in hub bore, and not an issue, but this is the first confirmation of the compatibility. I have a spare Taycan wheel that I would love to use as a spare for my Macan in the event of a punctured tire.
They told you the wheels were cross-compatible? I don't think Taycan wheels will work on a Macan, you could be in for some real problems doing that.
Your warranty will most definitely not cover any damage caused by putting Taycan wheels (not listed as compatible by Porsche) on an electric Macan.
soundman
Rob
Scotland
Macan 4 EV
Difference in bore is not a problem. Brake caliper housing is much larger on the Macan so you need wheels with a larger offset or you might need a small spacer to give clearance.
soundman
Rob
Scotland
Macan 4 EV
They’re just wheels, if the specifications are the same there won’t be any issues And you don’t have to use Porsche wheels either.
Same here. I was told by the parts manager at my dealership that he could not guarantee they would work and recommend not doing that.
GermanPorscheLover
Marty
Los Angeles
Macan 4 992 C4s
Hello Soundman,
I also have a Macan 4 and want other 20" rims. with he Taycan wheels there is a lot more to choose from.
Any issue with your setup so far, what tires are you running??
Macan XA EV : Front: 7.5Jx20 ET 32 Rear: 10Jx20 ET 49
Taycan : Front: 9Jx20 ET 54 Rear: 11Jx20 ET 60
It looks like they should fit. I only compared the rear wheels but need to go with 295 width instead of 285 as the rim is 11.00 in width?
Best Regards/ Viele Gruesse
Martin
Electric Macan EV Will winter wheels & tyres TPMS from Taycan Cross Turismo work on Macan 4EV? WhatsApp Image 2025-09-15 at 13.30.39_8aa193ba
Electric Macan EV Will winter wheels & tyres TPMS from Taycan Cross Turismo work on Macan 4EV? WhatsApp Image 2025-09-15 at 13.30.39_6602cac9
