Front noise when turning
nulled
This is the third time I’ve noticed a noise coming from the front wheels when turning the steering wheel all the way while reversing out of a parking spot. It sounds like a sort of clunking noise, and I’m not sure if it’s related to the air suspension or just the brake discs. Has anyone else experienced this?
BigApple
Andreas
NJ
Macan Turbo EV, E-tron, M3
Yes same here. You may miss it if you play music. It is scary. I did not notice it at first. But this last week I noticed. But not only in reverse. In both directions.
nulled
nulled
I can confirm it happened also in D on a steep climb while again having the steering turned all the way.
nulled
nulled
I've heard a noise while maneuvering in our underground garage, but that was just the tire losing grip while at full lock and skipping on the tread blocks.
The sound reminded me exactly of that but I was on a completely flat surface...
I was on a flat surface as well. That’s not the issue though. The thing that can trigger this is having the steering wheel turned, with full lock being most likely to cause this.
nulled
nulled
I spent a few hours driving today and tested the steering in both the left and right locked positions, but this time there was no noise. Makes me wonder if the cold weather might have something to do with it.
