PCM and Apple Lossless Music
terence
Macan EV 4S
I'm brand new to the forum. Hello everyone!
Just took delivery of my 4S. So far very good. Does anyone know if the PCM can play Apple Lossless files? I put my music collection on a pen drive and plugged it in the car. The PCM reads the contents but cannot play the music (it says error). Any thoughts/experience?
Thanks in advance.
IonPowr
ca
Tesla Roadster, Tesla M3, Mini Clubman JCW
Apple Lossless should be a file with a .m4a extension. According to the owners manual, that should be fine.
File extension
.mp3;.wma;.asf;.m4a;.m4b;.aac;.flac;.mpg;.mpeg;.avi;.mp4;.m4v;.mov;.wmv;.3gp;.mkv;.ts;.mid.xmf;.mxmf;.rtttl;.rtx;.imy;.ogg;.webm;.wav
terence
Macan EV 4S
Thank you! I tried downloading Amazon Music and play it through the app but same results. Has anyone tried and succeeded in playing .m4a files?
ScottHarder
Scott
Macan 4 ev
I just tested both m4a and flax audio files. Both played fine. Macan4S/USA
terence
Macan EV 4S
I put 3 files on the drive (.m4a, .flac and .wav). Only the .m4a does not play. They other play fine. Any thoughts? I'm in the UK btw
Do your .m4a files play on other devices or cars?
ScottHarder
Scott
Macan 4 ev
I also suspect the .m4a files that do not play are DRM protected. The .m4a file I tested with (see post above) is not. That file does play on other devices (Mac QuickTime Pro, Sonos).
terence
Macan EV 4S
I have played it on other systems (VLC on windows and android, and some others) but it's all fine. Is there a way of telling if it's DRM?
terence
Macan EV 4S
I converted the Apple lossless files to Flac and they play perfectly.
Dunno how you are getting media on the USB stick. But there is something about conversion and just copying files from the media folder thats different. Conversion/export removes DRM, but, last I checked, Apple doesn't allow conversion of media you didn't buy. Last I checked, when you export lossless media, you get std quality audio.
So your mileage varies.
terence
Macan EV 4S
It's not a DPM issue. All the files are ripped from CD in the first place. I also checked on iTunes and no dpm flags. Pcm in the UK doesn't seem to play Apple lossless. I've had this problem in other android apps. I believe pcm is android based so maybe a problem. Maybe it's missing some codecs
