HELP--STUCK ON LOADING ACCOUNTS
Etmaniac
Daniel
BMW iX, Macan Turbo
Had the same issue when trying to add a second user. Deleted the secondary user via the app and the problem was resolved. Stay away from adding users...
thealbs
Manchester, UK
Macan 4S Slate Grey Neo
I just had the same issue. Car is 5 months old and has had multiple accounts on it since new, with no issues until now.
I disconnected the 12V battery for 3 minutes then reconnected and it all seems to be working fine again now. Seems that its the Porsche equivalent of CTL+ALT+DELETE ...
TeslaHater
Macan 4S, Volvo XC90 T8
How did you disconnect the battery?i popped open the frunk and see the positive and negative terminal but couldn't figure out how to disconnect
TeslaHater
Ok, problem is now fixed. As the post above indicated, it was related to the multi-user login. Until they resolve this, I would avoid trying to register multiple users.
Hi, I am stuck on the same loop when adding my wife as secondary user. How did it fix for you?
thealbs
Manchester, UK
