Are these original Porsche (Macan) rims?
krisdv
Macan 4S, MINI Cooper SE, Macan GTS on order
All dimensions are correct for front and back: 22‘ x 9J ET29 in the front, 22’ 11J ET47 in the back.
Bolt pattern 5x130, installed tyre size is correct, except centre bore is not correct.
Center bore of the wheels is 71.6 while Macan EV has 66.5 hence my question are the wheels aftermarket or Porsche, how can I tell?
Electric Macan EV Are these original Porsche (Macan) rims? Afbeelding1
Electric Macan EV Are these original Porsche (Macan) rims? Afbeelding2
are they ICE macan wheels?
the center bore for the ICE is different...
krisdv
Aftermarket. Macan ICE wheel. Nothing like that was ever offered from the factory for the Macan EV.
Edit: Thanks to krissrock for identifying the actual wheel.
Thank you for your input, unfortunately bolt pattern Macan ICE is 5x112, these are 5x130 and 22"
krisdv
Porsche Cayenne GT has similar wheels in 22" but different size, 22x10J ET48 front and 22x11.5J ET61 in the back.
jm1883
James
Manchester, UK
Had these wheels on my 2024 ICE Macan GTS, pretty sure the genuine ones were only 21’s
