Disappointing navigation performance
DrasonDE
Dan
DELAWARE
Porsche
I’ve had my Macan 4s for two months now and love it, but….the navigation system is a huge disappointment. The HUD does not always correspond to the map In the display, it suggests turns and u-turns that are simply non-sensical, the Porsche charging route planner suggests ridiculous detours when the battery has more than a hundred miles stored, and its estimates of arrival times are often way off. I’ve surrendered and now use Google Maps in CarPlay and don’t use the route planner. Have others found this and, dare I ask, is there a fix? (I read the horror stores following software updates, so I tread lightly before going there.) Thanks!
Robert
Orange County
2025 Macan 4S, 2022 Cayenne Hybrid Coupe, 2013 Cayenne Diesel
It worked well the first 8 months but the Porsche navigation system has become unusable for me. Recently, it wanted me to do two charging stops, the first 4 miles farther than the closest station. It also tried to direct me to every charging station (EA, Charge Point, etc.) along my 25 mile route with 100 miles of range indicated. It no longer shows the number of available chargers at my destination and the battery estimate upon arrival is always around 25% regardless of the SOC. It might be correlation and not causation, but I swear it went bad after getting the big software update.
Greybeard72
Daniel
Westchester, NY
My understanding was that they: 1) use google maps as a base 2) connect with cloud based algorithms to do the planning.
I suspect they are struggling with the myriads of new chargers (and CPO's) coming on line in the US (maybe in the EU and other parts of the world also). They have also added lots of 'choice' in preferences for charging point operators in the app and the car.. hence all that additional complexity may not be reflecting properly in the algorithms they are using to do planning. When it was limited to EA and CCS only they seemed to do a passable job. Now that they have Tesla and IONNA and others thrown into the mix with new ones coming online all the time, they seem to be having a harder time. Not to mention that they have to process real time information on availability to add to this. I've noticed that the reliability of ABRP has also gone downhill since they have a hard time keeping up also. Not to mention that using Google proper is not terribly reliable either (they seem to miss many stations and not update reliably when they come online).
I have had issues as well since I like to avoid they Applegreen chargers unless I have no other choice but they insist on putting them on my route even when other options are available that are cheaper and just as reachable. There seems no completely reliable solutions here. I do like that they do very quick adjustments as you change/eliminate charging suggestions that come up. I'm not, by any means, suggesting they shouldn't improve but keeping up with 'optimizing' routes these days is not easy.. for anyone. That's both the bad news AND the good news. :)
skshimer
Skip
Southport, NC
I started using ABRP with subscription, which has many more options and works well in CarPlay. Someone posted you can start ABRP in CarPlay, and then hit the PCM Navigation icon and your route and charging stations will be there. I haven’t tried that yet. Tomorrow on my way home I will try it.
skshimer
Skip
Southport, NC
When using ABRP I get the turn directions in the HUD and the ETA in the dash next to the current. I lose all the animation and lane graphics in the AR HUD. ABRP did connect well through Enode and had an accurate current SoC and a good estimate of SoC at the destination. I will go back to using ABPR to plan trips and the PCM navigation while on the road.
DrasonDE
DrasonDE
Dan
DELAWARE
Porsche
Thank you for that information. I’ve downloaded the app!
Robert
Orange County
Edit: I've uploaded the latest example. At this point, I was approximately 2.5 miles from my desired charger with a direct route through residential neighborhoods. I might not be interpreting it right, but it seems it wanted to take me out of the way on a longer route, 5.7 miles, with two extra stops. My SOC was 23% at the time. Notice the upper right corner. It says it will be 46% when I get to my destination.
Electric Macan EV Disappointing navigation performance Porsche Navigation
You’ll be at 46% because it added a charge stop for 5 minutes
it’s likely you have a minimum charge at destination that’s set to 45% so it tries to do that here, but it makes itself look foolish in the process.
Settings Icon > Charge Settings(?) should show you this
Edit to add: Oh, it also didn’t take into account that the Destination IS a charger, so it ignored that in planning your charging stops.
Porsche thinks Charge Stops and Stopover/Destination points are entirely different for planning purposes
Robert
Orange County
My route setting was at 30% "minimum charge at destination." It makes no sense to send me to an extra charger as a stopover that was about the same distance but out of my way. And it's not like I'd run out of battery when I had probably 75 miles of range. It's a mystery.
Indeed. I can see how it did what it did based on their stated parameters. But it does make no sense to a human!
The trickiest part is that Charge Stops and Stopovers are not the same, and once you’ve added a charger as the stopover (destination in this case) it fails to be used by the charge planner.
It’s very quirky, but I’m starting to get a feel for it as I was working out the incorrect destination SOC for my car. That has now resolved after a long trip using the planner.
In your case, because you were below minimum destination SOC already, it MUST charge along the way, even if that makes no sense in this case.
German software can be very literal
