- Dec 7, 2024
- Los Angeles, California
- 2025 Macan EV Turbo
I put air in my tires this morning before leaving home to run some errands. Because I added air I wanted to monitor the tire pressures so I configured the left display tube to show the tire pressure, which I have set to display in PSI. The tire pressure initially shown matched the gauge of my air source, and went up by 2 PSI as I was driving about 12 miles to my destination.
I parked the car for about 30 minutes and when I was leaving I was surprised that the tire pressure now displayed in BAR instead of PSI. I went back into Settings -> System -> Units, and sure enough the PCM was configured to display PSI. I switched to BAR and then back to PSI, and the numbers in the left tube started showing the expected PSI value.
Come on Porsche, this can't be that hard...
