JohnnyRoaster
Outside Boston
I installed just the front FitCamX and have been happy with it. I tapped into the rain sensor and noticed it does record when I’m charging. Not a huge deal and my lazy work around is to simply pop the memory card out when I’m charging. I think it’s only level 2 and 3 but I need to confirm that. I don’t often plug into 120 except when I need to at a vacation home.
gfruda0622
Guy
Macan2025 EV Base
Just to close the loop on this, because I had to replace the 20V Fuse for my Accessory Outlets (Cigarette Lighters). There are three fuseboxes I found (I did not dig around the frunk) on my 2025 Base Macan EV. First in the Passenger Footwell. That seemed to have the most and driving a lot around the dashboard electronics. Everything there seemed to be Constant 12VDC, not switched, but its hard to test because the minute to lock the doors and wait for the car to shut down, if you move to test, the alarm goes off. Next was right above that on the door side right below the dashboard. Easy to access, again constant power, and much less fuses. The last place I found them (and also the one I needed to replace), was in the Trunk, Driver Side Rear by when the power comes in for charging. It is a simple carpeted cover you can easily pull off (one you raise the cover on the trunk floor. They had plenty in there, and a few extra connectors for I would think are accessories coverd in foam. I did look at the same panel on the drivers side door (opposite the passenge one). and didn't find any in there.
Hope that helps if people are still searching.....
Guy
