Dashcam installation issues -- fuse box location?
rusty94114
rusty
San Francisco
2025 macan ev turbo
Well I finally got my cameras installed.
Went with Viofo a329. I had the pre-wiring also for the Porsche cameras. I was able to, with some modification, use the video feed wire to connect to the rear camera. It only needs this cable and not a power source much like the Blackvue.
The fuse locations were clutch as were the trim instructions. Thanks again @Degenatron
The only casualty was one of the fastening clamps on the roofliner. Hopefully that is a piece that can be replaced easily.
I've attached the image of the piece. Seems like there is a better way to remove these that doesn't involve pulling down.
The back was certainly a bit of work versus doing this on a pre-wired Cayenne (only removing one piece of trim). This involved the four panels a torx screw and a 12-point m8 screw (got a bit at O'reilly for this).
I am trying to install the same system having trouble. Can we discuss?
Joder
Texas / California
Cayenne S, Macan EV Turbo
Hi @Joder I am doing the same install w Viofo A329S and Porsche prewire. Can you elaborate on how you did it? I just ordered the adapter for the power, and installed the 10 and 5 amp fuses. How did you connect the rear camera wire? Did you leave the voltage switch in place? did you stuff all the wires into the upper console? or shorten them?
Thanks
My car was pre-wired for the Porsche dash cam. I was able to use the Viofo cable. Basically cut it in half or whatever in terms of desired lengths. I then terminated it as others have mentioned. with the appropriate connectors that go into the pre-wire porsche connectors. I messed with the voltage switch a bit, however, it doesn't seem to stay on even at the lowest voltage shut-off level.
https://www.amazon.com/dp/B0B13Z4Q6K?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_6&th=1
Those are the connectors. I'll have to find where someone explained the splicing, etc. Some buy a tool to complete the crimp. I just did it carefully with some pliers. It does take a bit of handiness.
rusty94114
rusty
San Francisco
2025 macan ev turbo
I think I have the coax cables figured out.
I got the power adapter. But there is no power coming through the overhead console.
I added a fuse in the front trunk.
I added a fuse in the passenger foot well.
Do I need a software update or something?
Joder
Texas / California
Those should be the only 2 locations for fuses from what I remember. I'm trying to remember the power from the harness now.
Brightspark1
Robert
ireland
Macan 4 EV
Installed the fitcamX to my Macan 4 today and all went well.
Very fiddly to get covers off and connections were in slightly different location to my previous taycan. (You need to clip out the smaller connector nearer the windscreen which is located directly behind the bigger connector )
Plastic bits around mirror need a bit of firm force to remove and rear view mirror mount needed to be twisted off with a 10 dg turn anti clockwise , again with quite a bit of force.
Dash am is powered off rain sensor and no wiring needed, but no parking monitor as its only a switched supply
rusty94114
rusty
San Francisco
2025 macan ev turbo
I’m working on the rear dash cam. I see that there are two screws. I need to take out to remove the panels. Any other pointers? Looks like the panels just pry off. Need to remove panels around left cargo area, and top of window. It appears.
Brightspark1
Robert
ireland
Macan 4 EV
Didn’t get the rear view dash cam , but read somewhere to be carful removing the 2 screws as they can drop down easily and disappear
Iceman153
Mark
Vancouver, BC
Macan Turbo Electric, Land Rover Defender.
This thread has been super helpful. For those of you considering a FitCamX that have the factory dashcam pre-wiring, FitCamX actually has adapters that let you directly plug into the prewiring. When ordering the FitCamX they reached out to confirm my car model, and as an aside in my reply I asked if they have adapters for the factory 6pin pre-wire connector. They said they did and included one in the box for free. Sure enough the dashcam came out with both the rear view mirror adapter AND the dashcam pre-wire adapter. Have not installed it yet, but it looks like the correct plug.
I've also been looking at options to leverage the rear camera pre-wiring, and it is potentially possible if you get creative and leverage both the coax and wiring connector. But since the pre-wiring in the rear isn't actually run all the way to the trunk lid, it's still quite a bit of work removing all the trim to access it. It's probably about the same amount of effort to just run the rear camera wire in the headliner as it is to remove all the rear trim. It really makes you wonder what the point of the rear pre-wiring is...
