Door closing issue
nulled
Portugal
Uploading these here for feedback. I am still not sure if this is normal behaviour.
macanchan
Allan
that would drive me crazy. I hope it's an easy fix!
do the door seals look seated properly?
does the door latch/catch line up?
door trim hitting the dash board, door sill or anything else?
Macan EV to be delivered… or not
Normally, it's just a matter of adjusting the anchor bracket in the B-pillar, or the lock in the door. A suitable torx screwdriver should suffice. I don't have a Macan to confirm, sorry!
nulled
Portugal
On top of it, if it doesn't shut properly when I am inside, the car shuts down and I need to turn it on manually after shutting the door properly. 🤦
macanchan
Allan
let the dealer fix it.. the doors are heavy and they use a dolly/stand to hold the door to make adjustments.
nulled
Portugal
Rear doors close with much less force. So the problem is only with the front doors.
