In the UK you really have two options if you want to be able to access the special EV overnight deals. They have to be smart chargers which Octopus and other such specialists can integrate with. Many chargers will claim they can but they can’t unless the car can be accessed directly which I don’t think the Macaon can. The two are Zappi and Ohme Pro. Zappi has the benefit it integrates with solar if you have it or may get it. It also has the better app on my opinion. I have one and it has been faultless over 3 years with my Polestar. An added advantage is you can have it installed on a bespoke pole away from the house if you want to. Where we have it we can back to EVs up to it. I would also advise seeing if you can find a local specialist electrician trained in chargers. You will get a better service than going to a manufacturer whose contractors will want to do the simplest install even if it is unsightly. For example mine ran the cable via the loft and then underground to the pole so no unsightly surface wiring.
Zappi charger was my choice, cover all configuration wanted, mono or triple phase , untethered or tethered, good App, regular software updates, ideal if u have solar panels. Probably not the cheapest on the market.
