Manual charging door not opening
Cogs79
Quebec, Canada
Aaand now my right door doesn't open anymore. Perfectly sunny day although it is -12 C. I unplugged the car, tested the door a few times and it was fine. I checked the door, the connector etc. There was no ice or snow, just one small, dry leaf that I removed. After a 1 hour drive, the door does not open. It will be -33C this weekend, I guess I can't use the car because I can't charge it. Car was designed by amateurs. We all love how it drives...but I can't drive it if I can't charge it.
Cogs79
Quebec, Canada
Quick update: I left the car in my brother's heated garage over night (around 10-12 Celsius in the garage) but the charge doors still do not open. My Porsche dealer will schedule an appointment late next week but I don't think I will have enough charge to make it. Fun times.
pdealessandrini1930
Paolo
Montauk, NY
Hi.
couldn’t agree more: love to drive my Macan 4, but can’t if I can’t charge it!
as said before, and am sure most hate me for saying it, Porsche is global leader in ICE engine, transmission, suspension, aerodynamics . Novice for a smartphone on wheels šŸ˜³šŸ˜±šŸ˜µā€šŸ’«šŸ«ØšŸ¤£
When placing factory order specs, I purposely ordered manual charge port doors thinking naively that if I couldn’t open electric auto open charge port doors with a dead battery then I’d be dead.
I too experienced charge port doors that wouldn’t open.
Dealership advised it was a malfunction included on a Porsche software update
I didn’t think that when we lock our cars, the features include electrically locking manual charge port doors too…. šŸ¤”šŸ˜‰
had enough charge to drive to dealer and got loaner. Software update due for my car also fixed my inoperable manual charge ports both sides.
suggest you contact dealership and have software checked.
best wishes.
Aigle836
Martin
Quebec, Canada
Boxster S SE 2004, Targa4S 2009, Cayenne Turbo 2014, Cayman GT4 2016
Seems to be a common problem. Not related to temperature, but some parts issue.
See in this review at about the 15 minutes mark where the Porsche Tech had to come out to open it.
Get your Porsche Center to fix it ASAP.
Cogs79
Quebec, Canada
Hi Folks, I confirmed it's a mechanical issue. The left door stopped opening yesterday all of a sudden. I charged with the right door no problem. Stupid me, I decided to try to get the left door opened just now by pressing it in and locking/unlocking. Now the right door does not open while my previous trick for the left door did not work. So there is a mechanical issue where the left door does not open, but the car thinks it is (without displaying any messages) and keeps the right door locked. The closest appointment is Feb 9 so I will need to limit my driving until then. And my rear hatch is rattling worse then ever, although it might be the rear wing as I can rattle it with my hand. I think I have spent more time in a Macan ICE courtesy car than mine.
FirstEV
Sweden
No need to wait until then. The head of the service department gave me a tip in case you ever need to open it manually. You can gently press with your fingertips on the inside of the painted part of the charging door and remove it. Inside, there’s a small latch you can press that forces the port open, basically like an emergency release.
If it’s a mechanical fault, it will usually stop working again once you close it back up.
Would you mind clarifying this: does this mean to wedge your fingertips/fingernails behind the painted panel and to pull straight out? How much force is required?
FirstEV
Sweden
Yes, exactly like that. One hand on each side and pull towards yourself and it should come off. Little force is needed but do not be excessive in it. After that it should be like a ā€black panelā€ behind it with the latch.
That is excellent information: thank you.
Cogs79
Quebec, Canada
Hi Folks,
I managed to get the left door open, and I narrowed down the issue to the lock mechanism. I had to quickly and firmly press-press-press while locking/unlocking, and at one point there was a mechanical clicking sound, and the door opened. Then when I closed the door and locked the doors, I heard the locking mechanism click. You can easily here this clicking at the rear of the car when unlocking the car. However I never heard this sound when the charge door was not opening. I have an appointment first thing on Monday, so I purposely left the right charge door stuck otherwise they will say nothing is wrong again. If they say it's weather (-20C on some days) that is still a major problem since my car charges underneath a carport so it's not like water gets in while charging. This would mean water/snow gets in while driving with the door shut. Anyway, will keep you posted on what the dealer says but I will not take the car back without a fix for this. I don't want to have to fight the car just to charge it.
Cogs
Cogs79
Quebec, Canada
The dealer called, and they ordered replacement charge door latching mechanisms. The parts should arrive middle of this week, with installation likely for Friday. They also had to adjust my rear hatch again, the latch itself shifted since the last adjustment. Crossing my fingers that this solves the charging door issues!
On a side note, I got a Taycan as a courtesy car! Enjoying it! It's different than the Macan EV in some ways, but also not different if that makes sense. I'll add a review after a few more days of driving. I always loved the styling, and it has a menacing presence for sure. To me this is part of the Porsche experience, a nice cappuccino at the dealer, and a wild courtesy car (wild to me at least). I see others having issues with their Porsche dealer which is unfortunate and unacceptable at this price point, so I am one of the lucky ones that have a fantastic dealer (Porsche Prestige Montreal for service since they are closer to my place, but also Porsche West Island where I bought my Macan 4).
Cogs79
Quebec, Canada
Hi Folks,
I got my car back last night! The work done on the charge ports is the following (lots of testing/diagnostics to figure out what was going on, but I'll list the more important work items below). Note that I had dropped the car off with both charge ports not opening:
-verified fault memory, no fault memory related to the issue
-verified extended identifications, control units for both flap doors, locking mechanism reads properly
-found SY, 9356 Charging socket (motor locking mechanism) for detecting plug defects (SY 82/25) however this bulletin is not exactly the issue that customer described
-performed drive link test for locking actuators, heard them locking/unlocking, issue did not repeat itself
-when looking at the actual value of the locking actuator, noticed passenger side was displaying as "initializing" and drivers side was switching between "open" and "closed" when operating the door flap
-noticed when locking the vehicle, passenger side flap was not locking while driver's side was locking
-ordered new actuator lock for passenger side
-removed old throttle control element as per diagnosis and replaced it with new one
Now we wait and see if this was the fix! I am glad they noticed the "lock/unlock" clicking (or lack of) when the issue was there. It's a very noticeable click at the back of the car when things are working.
They also fixed the rear hatch rattle (again for the third freakin' time). And they got the passenger belt clip added to stop that rattle. Hope this helps others having this issue!
Cogs
Cogs79
Quebec, Canada
Aaand my left charging door is not opening again. This was not replaced. The temperature might have touched -17C but it was around -10C when I got home. No rain or snow, and the roads are dry. The newly replaced right door worked but it's probably a different issue on the left door. I won't bring it to the dealer but I will let them know.
Cogs79
Quebec, Canada
Hi Folks, the dealer needs to replace my left charge port hardware. Parts only arriving in 3 weeks though. Not a big deal as I will try to sync it with winter-to-summer tire swap. On a side note, I got a Macan 4 courtesy car that is 99% identical to mine, except it has a HUD and the Electric sport sound. I tried the HUD and became nauseous within 5-8 minutes of using it, and am still feeling it a little almost 4.5 hours later. I have experienced a HUD in a rental car last year (Nissan Qashqai) and absolutely loved it. No nausea with the Nissan but man am I glad that my Macan does not have it. It almost felt like it was auto-levelling, or not moving with bumps. Not sure but clearly something is off for my brain/body to react this way. It was slightly blurry and too high (although that might be adjustable?). Anyway, I'll report back in a few weeks when they replace my charge door.
Cogs
