Pcm / preconditions
If you use ABRP then you can set the required state of charge at your destination. If you run it under CarPlay you can put the same charge stops etc in the cars charging planner and end up with the required soc on arrival. A bit of a faff but will work if it’s important.
In the UK the IONITY App will also calculate on the basis of soc at arrival - as IONITY and Porsche have done the deal they are I think the cheapest Ultra chargers in the UK.
Electric Macan EV Pcm / preconditions IMG_1049
Max charge at destination feature is not available on the Macan EV.
Ok I wondered - I have a 4S Macan EV for the weekend from tomorrow so will get better acquainted with the subtleties between Taycan and Macan EV.
Cannot wait. Please note full spec of the 4S and any apparent issues. Then make sure put it in the sportiest mode and try some turns and roundabouts and see how it handles. All 3 examples I drove had issues with body gaps, assistance error speed limit, plug and charge did not work, perforation in seats mismatch from front to rear, doors needed several attempts to close, charging flap was not flush, and as we know limited to 9.6kW in the US.
