Quick Question: if charging station added manually to a route in PCP does the battery get preconditioned?
poul
Poul
Denmark
Porsche Macan ev RWD
I going skiing in sweden tomorrow and are a bit worried about the temperature as it will drop to minus 24 celsius later this week, tried the routine putting the selector in sportplus today but no changes in battery temperature in 30 mins
MaccyT
Maarten
Netherlands
Macan Turbo / Audi Q3 TFSIe
Then you don’t have the Sport Chrono package ? As that option will make sure it heats up indeed.
you can just set a destination as DC fast charger no need to be as a stopover ... I tested this several times ...
I have a DC fast charger at 500meter of my door, I can set it as final destination do some errands and it will heat up the battery ... it will re route the complete time, but my battery will heat up an after 30 minutes to 60 minutes it will be nice and toasty.
You just need to make sure the Nav sees it as a DC fast charger, which sometimes is a hassle, so make sure you select the right address.
The sport plus will only work if you have the chrono package ... I have sport plus for suspension only, as I did not see the benefit, regret not have taken that cheap option.
Oh, really? Never worked in the Taycan like that for me and assumed the Macan EV would be mo different.
You'll waste some energy doing that. Interesting to learn if stopover works well for you.
racerjim
racerjim
Jim
Canonsburg, PA
2024 Mercedes Benz GLC300
Thanks, @Yves. I see the difference in the PCP. I do have chrono, so do have the option to use sport+, but that will be a last resort.
I have the Sport Chrono package. Sport+ does NOT heat the battery like preconditioning does
What may happen is that the car might be blocking the cooling of the car whilst driving to allow the battery to warm up a bit more before the cooling is applied, but you’ll need to drive around a lot to generate the heat if that is the case
One more note, when the car is preconditioning, you can stop and select the option to leave the car running and preconditioning will continue during this time. You could do this waiting at home if you live close to the charger!
  • Like
Reactions: MMR
ron_b
Ron
California Central Coast, USA
2026 Macan 4 (waiting at dock), 2020 Taycan 4S
To address a couple items in this discussion.
I am waiting for my car to get built in January but I feel reasonably confident that you could route to a Charger as a destination, and as long as you set the minimum charge at destination in the settings to a high value, such that the car would know it needs to charge them it would do the necessary preconditioning in route.
On the second topic of having a manual precondition button, which is discussed in a plethora of YouTube videos for all sorts of vehicle vehicles. I personally think this is the wrong approach for several reasons:
  1. A mere mortal would not know when to use such a button. You would have to know how quickly the battery could be heated to the appropriate temperature for the state of charge that it would have on arrival.
  2. If driving for over 30min the battery would be up to a reasonable temperature for discharging so charging would not be excessively slow. IMHO
  3. Heating the battery does take significant energy such that doing it manually when not needed or longer that necessary could end up extending your charging session due to needing more power.
There is another thread on battery preconditioning, but it gets a bit aggressive.
I hope to have direct experience soon. I did have a Taycan for 5 years and 100k miles.
icehot
Hampshire
Macan EV Turbo
I did my first "long" journey yesterday and on the way back I decided to put Fleet services as the charging destination when I was about 20 miles from it. The battery termperature didnt go above 18-19c. Wondering if I did something wrong?
It was a 180kW charger and I only got 60kW while charging.
ron_b
Ron
@icehot simply adding a charging station as a destination will typically not figure preconditioning as stated earlier in this thread. The car needs to think you need to charge. To accomplish that you:
  1. Have to put a final destination that would require charging and have the desired charging station as a stopover.
  2. Alternatively set minimum charge level at final destination to a high value like 70% and set charging station as destination.
What was your SoC before charging?
You can't rely on the headline output of a given EVSE which could be throttled back for many reasons outwith your control (shared supply, load balancing and so on). Add to this a non preconditioned battery and one which may not be best positioned to draw a maximum charge due to an already high state of charge.
icehot
Hampshire
Macan EV Turbo
Thank you, this is exactly what I did today and my battery temp went up to 32c
What Ron said got my battery temperature up considerably vs yesterday. Sadly however I didn’t charge at the services today because the one 350kW charger that was available was faulty. I had enough battery to get home so will just charge at home now.
poul
Poul
Denmark
Sportplus is only avaible with the sport chono package so yes.
But not any difference
I have arrived now in Sweden and the preheat worked fine with the charging planner???
I did a short test in ours yesterday. Battery and outside temp were both 56F when I got in. Switched it to Sport+ (we have the chrono) for the 10 minute drive. Still 56F when I arrived. I know 10 minutes isn't long enough to do a full precondition but it didn't even move a degree, let alone getting half of the way to 70F+ like I'd have expected. I assume somewhere in the 70F-90F area is the target range like it is for most EV batteries.
(Actually is did tick up to 57F for a minute before dropping back to 56F.)
MaccyT
Maarten
Netherlands
I Did the same test 2 weeks ago and it took like 20-25 minutes to heat it up almost 8-10 degrees Celsius and during outside temps of around 7 degrees Celsius.
Not sure if it’s a Turbo thingy or not ( I would not assume because for charging purposes also the regular Macan needs to heat up the battery pack).
All models have the same battery pack and size.
Stopover in Nav or selecting a charge location identified by PIRM (Porsche Intelligent Range Manager) along your route is the surefire way to precondition your battery.
