Rear Wiper Replacement
Bennie
Ben
Eindhoven, The Netherlands
Macan 4, MINI Cooper S
To complicate matters further: Purchased from Amazon: Bosch Aerotwin A297S €26.24 (front) and A281H €7.59 (rear).
According to the Bosch site this is what you need. I was earlier very satisfied with the Aerotwin, but have not replaced them yet. I have already seen that they are the right dimensions.
Degenatron
Being in the UK, I went to change the wiper blades but found all of the info in this thread to be wrong!
The US has Bosch ICON, whereas UK (Also EU?) have Aerotwin.
The wipers are:
Rear 95C 955 427 - 13.5" 340mm:
Bosch A332H (NOT A281H or A381H , wrong mount. NOT A360H or A383H, too long)​
Tip: I transplanted the black sleeve from the old wiper to make the Bosch one look prettier.​
Front 95C 955 426 A/B - 26" 650mm & 20.5" 530mm:
Bosch A639S (NOT 24". NOT A297S)​
The stock blades are a Valeo part would you believe, which explains why they only last 12 months :facepalm:
Where else did they scrimp on the XAB Macan? Besides software 😅
Electric Macan EV Rear Wiper Replacement PXL_20260411_084313326
Electric Macan EV Rear Wiper Replacement PXL_20260416_173456019
Electric Macan EV Rear Wiper Replacement PXL_20260411_085145109~2
Scotsman58
Weston, CT
2024 Porsche Macan 4 (leased); Subaru Crosstrek Hybrid; Toyota Prius
Based on a post earlier in this thread, and not having yet seen the latest post, I ordered a Bosch A360H rather than the A332H. As noted in the latest post, this one is 15" rather than the 13" of the original OEM wiper. But -- it fits, and seems to work well. The 15" covers more of your rear window and so far I don't see any downside. Had it out in the rain this morning and it was impressively quiet and effective.
Degenatron
Good to know the larger size works OK, I thought about getting that size to increase the sweep area as you say but stuck with the stock size. Main benefit being keeping the orginal look and outer sleeve.
I wonder what's the largest size you could get away with?!
terence
Macan EV 4S
Thank you souch for the information! Worked perfectly! Been searching for ages!
The wipers are:
terence
Macan EV 4S
Also the original wipers are really bad from day 1. I'm pretty sure these are much better.
