Surround View with Active Parking Support not available on 4S?
KBEV
K
NJ
2021 Taycan 2023 Macan GTS 2025 4s on order
Option has been problematic on Taycan and apparently not reliable. Suspect more software tweaking and testing before release.
Personally, I would never option it.
And that chart says "at the earliest" so it really could be into 2025 anyways when it finally becomes a orderable option.
taycanstuff
Ice Grey 4S
For us UK folks it's an option for the 4S - extra tick box which includes the cameras and parking:
£833.00
- Surround View
As ParkAssist (front and rear) including reversing camera, but also featuring a 360-degree surround view generated from the images of four high-resolution cameras enabling even greater comfort when manoeuvring. A junction view (from front and rear of vehicle) provides assistance at more complex exits. Images are displayed on the screen of Porsche Communication Management (PCM)
- Active Parking Support
The system automatically detects parking space. Once the system has signaled that the parking space is a sufficient size, the driver can initiate and control the parking process. The system automatically takes over the steering and the forward and backward movement of the vehicle. The Active Parking Assistance is able to park the vehicle in parallel and perpendicular parking spaces.
- Trailer assist (only in conjunction with tow bar).
This function helps the driver when reversing with a trailer by means of targeted steering interventions.
Notes:
All systems function within their system limits and require permanent monitoring of the driver
taycanstuff
Ice Grey 4S
Interesting, I was planning to spec the 360 camera, even though rear cam and sensors may have been enough.
what problems have their been with the 360 camera? I guess more tech more things to go wrong!
EVSE
NorCal
Audi
I think they mean the upcoming remote parking option
By calling Porsche NA customer service, > PSM main screen > “Parking” > “Show Surroundings View.”
Then, option for me since never had a use for my joker button, just set it up so now it serves that function.
Thanks Troy at Porsche NA customer service.
Is this not the same as touching the Parking Support button in the very bottom left of the PCM screen twice? The one with the car and the 'P' for parking?
First tap gets Parking Assist Mode, second tap switches to Surround View on the left of the screen.
Might be the same but o never could get your method to work more than occasionally. So why since my joker button was idle, decided to go that route instead.
In Drive, right after getting in, it often says 'Not Yet Available', but if you select Reverse first, it's always there, and then you can select Drive.
When pulling up to my home after a journey, it always works though. There's some weird software interaction going on with it right after power-on.
